FINALLY!!! - Start Of Building My Oven
  • Laku
    Re: FINALLY!!! - Start Of Building My Oven
    4.76 mm.
    Here's a useful trick, type "3/16 inches to mm" in google's search field and push search it'll to the math and conversion for you.
  • Oven_Man
    Excuse the blond question but in millimeters what would the diameter of that bolt be?
    Regards
    OM
    I make my own 1/4" rivets, but unless you are experienced in fitting them you risk splitting the handle. I suggest you use 3/16" stainless steel bolts.
  • Oven_Man
    Hi David
    I just wanted to check with you what bolts do you suggest i use for the Peel.
    I don't want to use Galv considering how poorly it handles heat - is there any other material you can suggest?
    Regards
    OM
  • Oven_Man
    Hi David
    I kept the oven fired for approx 9 hours on Saturday and about 5 hours on Sunday.
    Yesterday's firing produced no moisture when placing the plastic over the Outer Vermiculite Shell. I checked it a few times from when the firing was started till the end.
    I'm certain that I've driven out most of the moisture.
    Anyways the oven will sit for the next 2 weeks before I close it off with the stucco.
    Regards
    OM
    Yes, but keep the fire gentle. Don't try to fill the whole chamber with flame yet.
  • Oven_Man
    Hi David
    I was just wondering whether keeping the oven fired up all day today will helpdrive out the heat faster?
    OM
  • Oven_Man
    Hi David
    I tried the neat trick you showed me with the plastic and indeed there was moisture trapped underneath the plastic so I guess I'll be firing the oven a few more times till its all dry. Its weired how dry the outside feels yet there's still so much of moisture trapped.
    Thanks for heads up on that one - saved me from repair work later.
    Regards
    OM
  • Oven_Man
    It seems dry on the outset but I've got a final firing today. I'll definately try the plastic trick and hopefully all is well - I'm so excited to close of this oven tomorrow.
    If I do find condensation, do I just keep firing it for another couple more days?
    OM
    Think like you are icing a cake. That brew works up to a very workable mix. Are you sure all the water has been eliminated because if it isn't you risk cracking the outer shell from the steam pressure. If you throw some plastic sheeting over the dome while firing, if water is still there it will condense on the underside of the plastic.
  • Oven_Man
    Cool, will do.
    I've cancelled my plans and decided to stucco the oven sooner than I thought. I've bought the lime and everything else I need.
    Regarding the render, you said I should use 4:1:1 Sand, Cement & Lime. How much water should I be adding to the mix?
    OM
    If the vermiculite is a bit crumbly it will wear away so you could render over it.
  • Oven_Man
    Oh yes, now it rings a bell how I supposed to do this.
    Damn, why did I have to ask them to bend it I'll have to try and bend it back (But this stuff is very tough) or make some other plan.
    Any advice on the other 2 questions?
    OM
    Go back and look at post #197 If it were mine I'd hammer the bend flat again.
  • Oven_Man
    Hi David
    Thanks for your reply. Rivets sound good although now I'm concerned that I shouldn't attach the rivets or screws through the front but rather on the top across the grain.
    I have attached a picture of the Stainless Plate showing the 30mm lip i created. Any advice how I can attach the wooden handle to this?
    Just another question ... or 2
    When I initially did the oven, I surrounded the oven floor with vermiculite, and then i placed the dome on the vermiculite but I didn't take into account the oven opening and now at the opening, I have this patch of vermiculite exposed.
    1) Is it safe just to leave it and use the oven like that?
    2) If not, what can I do there since this stuff is very hard.
    OM
