How to fit in your oven
  • tusr18a
    Re: How to fit in your oven
    I struggled with this task too. I could only fit my head and one arm through the oven door. I took two of the four legs off of a table. Put the edge of the table without the legs on the ledge in front of the oven door. I stretched out flat on my back on the table and then pushed one arm and my head through the opening. Talk about a pain in the neck. I ruined a good pair of glasses with all the mortar that fell on my head. Definitely do not want to do this task ever again.
  • Les
    Originally posted by Wiley View Post
    Here's a pair who could clean or repair a WFO:
    Contortionists In a Cube - Jokeroo
    Takes a moment to load, but worth the wait.
    Bests,
    Wiley
    That is absolutely INSANE!
  • fxpose
    I cleaned up the courses as I went along so there was no clean-up to speak of inside the dome.
  • bigred
    karagie....i think you confusing milimeters with centimeters....2.54 cm per inch and 25.4 mm per inch so 175 mm / 25.4 mm/in is 6.9 inches
  • Wiley
    Bests,
    Wiley
  • Faith In Virginia
    I used a mirror.
  • bigred
    according to your first post...you are only 175 mm tall....thats 6.8 inches...so you should fit easily....LOL I know its a typo.....I am also clostro and had to be pulled out 5 times..and I am 230lbs and 5'-11".....to make it easier take a shop vac and bring the suction hose into the ovenwith you ..it will create a nice fresh air flow into the oven and give you some relieve. if you want to have fun...try turning off the vacuum and see how long it takes you to freak out....thats what happen to me.
  • Alter ego
    I cant work out as to why you would want to have the inside of the oven "clean"..... ?
    Brickie, that's because we don't have your brick laying skills and had to get inside our ovens to clean off the dags of mortar.
  • GianniFocaccia
    As a spelunker who has over the years squeezed through a few cave "mouse holes" that were too tight to get through without exhaling, I know the feeling well, and it is something not easily accepted by one's brain. Because of this, I consider the act of climbing into one's oven to clean it the same as being inserted into a chamber (which I've done also) to have an MRI: piece of cake. At least if I ever got stuck cleaning my oven and there's still a hole on top my wife could hand me a cold one!
  • Wiley
    I fit although there wasn't much room for a table and chairs,
    If one doesn't have a WFO large enough to get into, how does one make repairs? Or is such a WFO a tear down and rebuild should repairs become necessary?
    Bests,
    Wiley
  • Les
    Doug, Your pictures freak me out just looking at them - I am claustrophobic. That's why I went the route I did, no mortar. There was no way I was going to crawl into the hole.
  • brickie in oz
    Originally posted by Alter ego View Post
    to clean up the bricks without the outer arch stopping access.
  • Huhness
    there was no way in hell my shoulders were fitting through my door
    Lucky I cleaned most of it up while there was still a hole.
  • RTflorida
    I sent my daughter in, child labor laws be damned
    Seriously, she was an adult at the time (22) and considerably smaller (OK, skinnier) than dear old dad.
    RT
  • Alter ego
    When I did my oven I did the outer arch and vent after I finished the dome so it was much easier to fit inside the oven to clean up the bricks without the outer arch stopping access.
    That said, it was still difficult & uncomfortable!
    It's a good looking build Doug.
