What Tools are Necessary?
  • mrchipster
    Re: What Tools are Necessary?
    I make bread and it is used to mop the floor prior to baking bread. It adds moisture to the oven giving the bread a better crust and texture (think holes).
    It also takes some of the heat out of the floor to prevent the Bottom from burning.
    And lastly it cleans the ash off the floor. Nice clean bread.
    Chip
  • Erdbeereis
    Originally posted by mrchipster
    Erd,
    I do find that I use the Blow pipe enough to justify having it; it does a great job of blowing of the last bit of ash from the floor. Mine is just an aluminum Cross Country ski pole with the handle removed and tip cut off. Others have used metal shaft golf clubs (head and handle cut).
    I do not have a shovel I use the banjo (turning) peel for removal of ash.
    Tools photo left to right
    Mop - BTW currently frozen stiff
    Brush
    Baguette Placer (think Peel that rolls bread off gently to the side)
    Rake
    Blow Pipe
    Pot Hook -- also works well to move wood around
    Banjo Peel (Turning Peel)
    Perf. Pizza Peel
    Chip
    Thanks! What do you use the mop for?
    Erd
  • mrchipster
    Originally posted by Erdbeereis
    Thanks! So the actual oven tools that one would need are the following? Peel, turning peel, rake, shovel, brush?
    Erd
    Erd,
    Brush
    Rake
    Blow Pipe
    Perf. Pizza Peel
    Chip
  • Erdbeereis
    Blow pipe, 8 inch banjo peel, hook to pull pots and pans, brass brush, rake / hoe, ash bucket, some way to light up inside of oven, well insulated door, IR thermometer, cotton mop with ringer, blast door, hot pads or gloves, a nice set of cast iron pans and enameled cast pots, rib rack, beer can chicken rack, perforated pizza pans (optional), pizza peel, roll of parchment paper, proofing linens, proofing trays, pizza cutter
    several of my tools have aluminum handles, they are very cold to hold when it is below freezing. Wood is much nicer.
    That is it for now.
    Chip
    Erd
  • mrchipster
    Chip used to live in the Amazon jungle an catch his own food.
    Now it is only good for keeping the fire lit.... Well and getting squirrels for lunch.
    Chip
  • brickie in oz
    Blow pipe,
  • Lburou
    That is it for now.
    Chip
    .....And a partrige in a pear tree.....
    Go Big Red!
  • mrchipster
    That is it for now.
    Chip
  • Erdbeereis
    started a topic What Tools are Necessary?
    What oven tools do you guys think are necessary for the residential pizza oven user?
    Erd
