Improving 'floated' finish on concrete countertop
  • Greenman
    Re: Improving 'floated' finish on concrete countertop
    It is heartening to hear your positive confidence. That is why those of us who are into forno porn are watching closely.
    A lot of these people are also into forno food porn as well.
    If you have to have a vice it is not such a bad thing to be inclined to.
    All the best with your build.
  • RichC
    I will definitely post some. This is going to be a thing of beauty!
  • Greenman
    Hey RichC how about some pics?
  • RichC
    Just repoured yesterday. Floated, then when it was starting to go off, trowelled. Much smoother surface to work with! Can't wait to polish.
  • stonecutter
    Originally posted by RichC
    Rented a con saw and cut the counter out last Saturday. What a horrible job using a con saw!!.
    Think that's fun, cut in a 3000sqft flagstone patio for 8 hours. Now that's fun.
  • RichC
    Rented a con saw and cut the counter out last Saturday. What a horrible job using a con saw!! Anyway, when I removed the shutter there were visible gaps where the concrete wasn't vibrated in properly. Glad I cut it out now. Thinking if taking Friday off work and redoing it.
  • Tscarborough
    You can cut the wire with a segmented saw as long as it is embedded, but if it hangs on a piece that is loose.....
  • stonecutter
    You can do it, but it's safer with a continuous rim. Go slow.
  • RichC
    Damn, the blade I have is segmented. Might work out cheaper renting a con saw with blade for the day
  • stonecutter
    Yep,but use a continuous rim blade, not segmented.
  • RichC
    Thanks guys but I'm going to redo it. Just not happy with it and I'll be looking at it for a long time. It's 50mm at the thinnest to about 70mm in places with steel mesh about 3mm thick inside. Will I be able to cut that with my grinder and diamond blade or should I rent a consaw?
  • deejayoh
    Originally posted by Tscarborough
    You can also make a slurry and coat it before grinding it to fill the holes and trowel marks.
    This
    You'll be amazed at how well you can fill all those bugholes. Mix up some portland and latex additive and work it into the holes. I found it worked best to do it when you are at about 800 grit - set your grinder on slow, and use the pad to work the slurry into all the holes. Then go back over with 800 once it dries. Found that on some concrete countertop website and it worked a treat
  • Tscarborough
    You will grind off 99.3% of it, so don't worry about it popping off.
  • RichC
    Can't cast upsidedown Stonecutter. Its a single piece with the oven sticking up out of the middle and sloping away on all sides.
    @Tscarborough Because they're not just pinholes I'd have to put a skim coat on the whole surface. I'd be afraid of it breaking away in chunks as it expands and contracts due to weather or is that unlikely? Anyway, I reckon I can cut it out in a few hours and Repour in about a half day
  • Tscarborough
