Re: Insulated door question
I did basically what you're describing for my original door. Foil wrapped insulation board skinned in hardi-backer that was then skinned in lightweight aluminum roll flashing. I wrapped the edges and held the whole thing together with adhesive aluminum flashing tape. It worked fine for several firings, but eventually the heat got to the tape adhesive and it came unstuck and the hardi-backer started to deteriorate. At that point I brought the whole thing to a welding shop, where the hardi-backer served as the template for an insulated steel door. Cost me $200.
I have two doors to make. The inner, insulating door will be made like this:
2 peices of AAC approx. 3" thick will be bonded in the middle, cut to the size of the inner arch with a 1" lip. I will then cut it in half vertically (at a 45 degree angle through the door so the sides lap). I will then coat the edges with thinset, thinset two AAC handles to the back, and coat the exterior of the doors with thinset.
The outer door will just be wood, and I hope to hinge it like shutters. It is just to keep out bugs and moisture.1 Photo
So, as I understand it, your insulation is directly exposed to your cooking interior, a large wide face of it no less, not just a small seam in an unwelded box.
One thing is, I already have lots of leftover InsBlock 19 lying around from my hearth insulation. I may as well use it up instead of buying something new.
Gee, you like to make hard work out of it!
For my door, (ie. the insulated removeable door rather than the 2 cast aluminium doors), I cut a 1/2" piece of plywood to size and shape to fit into the oven entrance up against the rope seal. I then got some expanded metal and cut it also to size and shape to fit the plywood but with a 2" void into which I cut and inserted 2 layers of 1" superwool blanket. I then pushed the wooden backing into the folded metal housing and nailed it to the wood through the holes. You could also run some insulating sealing rope around the front edge perimeter if you don't have a good sealing edge in the oven entrance. An hour all up and ready to go.
Neill2 Photos
I am attempting to design an insulated door. The interior face and 2" thick sides will be sheet metal enclosing a cavity (2" of course). The exterior face will either be metal or hardwood, I haven't decided yet. The cavity will contain 2" of InsBlock 19. Problem is, I don't weld. The sides will consist of tabs folded over from the inner face, then wrapped along the outer face. I might wrap a strip of metal around the edge over the tabs (riveted to each tab) but there will still be cracks and tiny holes at the corners and folds. I am not comfortable with exposing the InsBlock 19 to the oven interior in this fashion.
Thus the following proposal: What if I wrap the InsBlook 19 in foil before placing it in the door? I could either use ordinary kitchen foil (or the heavy version thereof) or perhaps some sort of flashing, any extremely thin metal would do of course. I have seen extremely thin copper flashing at HD for example.
Assuming enough "wraps" were laid around the InsBlock 19, do you believe this would adequately contain any outgasing or vaporization despite a lack of a true sealed compartment?
Additionally, would wrapping the insulation board in foil defeat the purpose of the insulation by letting all the heat transmit around the edges through the foil? I figure, if that were a real problem, then the heat would already be transmitting around the edges of the exterior sheet metal anyway, so this shouldn't be a problem (not any more so than it already is at any rate), but I just don't know. Since lots of doors have an inner metal face that wraps into metal edges and then right to the exterior of the door, it seems like heat loss through the metal comprising the door isn't generally a serious problem.
What do you think?Tags: None
