Hello,
I grew up in New Haven CT, and was weened on great pizza, including Ernies, Sallys, Modern, and Pepes. I lived in Manhattan for 20 years so I still had access to some world class pizzarias (ALL FIVE OF THEM). None the less I have been cooking pizza at home since I was a small child due to my father becoming orthodox (Jewish) and dragging us all into that BS with him, so I had to try and recreate edible pizza at home. I have used numerous stones over the years including the useless round 1/4 inch thick variety.
Now I am in Jerusalem Israel on a contract programming project with my brother (I am not religous in any sense) and the food in general is beyond grotesque here, let's not get into the horrible excuse for pizza! Recently at a high end home baking equipment store here I found the holy grail! The owner had 10 so called Italian Pizza Bricks (really a pizza stone) a little over an inch thick, and wooden peels (unfortunately with a long handle). I bought the stone and peel and downloaded your guide just to learn new things, and see if I have been correctly placing my stone all these years. I made my dough a produced three pizzas today (I waited 20 minutes between each one to make sure the stone was back to about 550 F. I actually tested the stone temperature at 545 degrees F with an infared laser thermometer my brother and I use to check circuit board temperatures.
My oven here has a rear 4" inch convection fan, a top visible thick wire element, and a bottom element under the floor panel. I put the stone directly on the oven floor and set the combo mode so all three heating methods were on. I set the stove to it's MAX setting and let it heat for 1 hour. My problem is that the toppings and cheese seem to be about to burn before the dough has any real good blistering or char marks. I was thinking about raising it just below the convection fan but, it seems that would cause the top to cook even faster. The pizza came out more like home made pan pizza than the brick oven look and feel I was trying for (and have achieved many times over the years). Any suggestions?
Also as you may or may not know, the famous New Haven Appizas do not use fresh Mozzarella, but rather Grande Whole Milk Mozzarella from Wisconson, or Kraft Polly -O- whole milk Mozzarella (Ernies uses Polly -O- and Alta Cucina Tomatoes rather than San Marzanos). Have you tried making conventional Pizza Napoletana but substituting Shreded Grande instead of Fresh Mozzarella? I am trying to get the New Haven Modern, or Sallys style look, feel and taste here.
Thanks in advance for any suggestions!
Moses
Moses
