I have seen and read several Internet Cooking Stations that recommend and show you how to season a pizza stone.
I'm a little confused about the science behind doing it.
A pizza stone is porpous and this material enables the stone to draw moisture from a pizza and make it crisp.
However, I run a super hot grill with air temps over 600 deg and stone temps of well over 700 deg. I have burned a couple pizzas in 3 minute cook times and the pizza will stick to the stone.
Seasoning does offer a non-stick surface, which is enticing.
The question I have, is if the stone is seasoned will it still remain porpous enough to remove the moisture from a pizza and produce the cripsness?
Has anyone experimented and tried cooking pizzas on both a seasoned and non-seasoned stone? If so, plase share your observations.
