I just got some Caputo flour and tried the FB dough recipe. In my first two attempts I couldn't get the dough to brown up. I ended up overcooking them thinking a little more time and they will darken. I have an electric oven and a massive stone (hearthkit). I heat my oven up to 550 for two hours, my stone gets up to 540 before cooking. Later I adjusted the dough recipe. I added a little oil and mixed in my regular high glutten flour in with the Caputo flour. I ran out of Caputo and didn't want to open another one so my mix was something like 70% regular flour to 30% Caputo. Well bingo my crust browned no problem. Because I made two changes, flour and oil, I don't know which solved the browning problem.
Yesterday I ran across Jeff Varason's blog. It's quite good well worth the read Jeff Varasano's NY Pizza Recipe . He uses a wet kneading process which makes sense and I'm going to try. He confirmed my suspicion that the flour maybe the problem. Jeff wrote...
"The 00 has a finer mill and also it will absorb much less water than the other flours. The 00 flour really is quite different than the others. If you are baking at under 750F, you should really not use 00. It will never brown and you'll have much more luck with another flour."
Now I'm beginning to wonder if FB recipe is really suited for stone baked pizzas. What's your experience?
