Pizza Dough Calculator
  • Pizza Dough Calculator
    Found this site and this handy tool for getting perfect proportions each time based on how you tailor your individual recipe
    http://www.pizzamaking.com/dough_calculator.html
    It's fantastic. Note that it is tailored to the NY style pizza.
    I use it myself every time I make dough and it is nearly foolproof. I have found that a lower hydration percentage seems to work better in my Forno, insofar as I am outdoors and it is (lately, anyways) more humid outside.
    There is nothing quite so satisfying as drinking a cold beer, while tending a hot fire, in an oven that you built yourself, and making the best pizza that your friends have ever had.
      While tailored to NY Style, you can adjust the factors to get you a Chicago, neoploitan, etc
      Great way to determine dough needs especially if planning for a large party, or just wish to 'tweak' one element at a time and get accurate baker's percent / ounces etc.
        Re: Pizza Dough Calculator
        thats great, thanks for the link...JR
          That is very cool. A few questions.
          1) Why does it say do not use extra virgin olive oil?
          2) could someone post a recipe they have used sucessfully, so that I can use the same factors and modify quantity.
          Great link!
          Drake
          My Oven Thread:
            EVOO as a topping - absolutely. EVOO in the dough - not as significant a difference in taste.
            As all I buy is EVOO - always use regardless of what a recipe says.
              Richard,
              Agreed. EVO is fine as a topping, but once the heat hits it in a dough, the difference is so minimal it's beyond nothing.
              Jim
                Ok so they say it is a waste, I understand that...They should say EVOO is not necessary instead of Do not use evoo...
                My Oven Thread:
                  Drake:
                  I use to bake pizzas using several formulaes from pizzamaking.com.
                  Since I have a wood oven, the Tom Lehmanns New York style, with preferment and/or the Varasano´s Patsy pizza were always a winner.
                  The TL NY formula, in Baker´s percent, is
                  Flour 100%
                  Water 63%
                  EVOO 1%
                  Preferment 10%
                  Salt 1,75%
                  with 24 hours rest in refrigerator.
                  More information about the process could be founded in pizzamaking.com/forum (specifically in the thread Tom Lehmanns NY Style pizza, replies 151, 161 and 165).
                  Luis
                    Hi all — longtime lurker, first time sharing something I built.
                    I've been making pizza for a few years and kept running into the same issue: most calculators either cover one style or don't handle sourdough properly. The other thing I kept missing was a way to work backwards from a target time — I want the pizza ready at 7pm, so when do I need to start bulk fermentation? I built my own to solve both and figured I'd share it here.
                    It's a free, mobile-friendly web calculator at jordospizzacalculator.com/app — no app install, no account needed.
                    What it covers:
                    • 5 styles: Neapolitan, New York, Vito Iacopelli, Detroit, Chicago — each with style-specific hydration ranges, oil percentages, and ball weights
                    • 4 yeast types: IDY, ADY, fresh yeast, and sourdough starter (with an adjustable starter % slider)
                    • Target end time input — enter when you want to eat and it works backwards to tell you when to start each stage
                    • Oven type selector (home oven, wood-fired, outdoor gas) which influences some recommendations
                    • Fermentation time input with a warning when time/yeast ratio is off
                    • Recipe history (last 10 results saved locally)
                    • Imperial/metric toggle
                    • Dark mode
                    Nothing revolutionary, but it works well on mobile and covers the styles I personally use most. Happy to hear feedback if anything's off on the formulas — the Vito-style ratios in particular I've tweaked a few times. I hope you like it.
                      Looks like a useful tool Jordos. My only comment is that some of the user entry boxes don't have adequate contrast between the background and user entries. For example, when I entered the number of dough balls in the default setting, I could not see my entry until I changed to daytime mode (or dark...wasn't sure which screen mode I was in). My entry was showing as a very faint gray on a white background . I thought my entry was not being accepted and kept tapping a number...555555 pizza balls would've probably been more than I needed . Anyway, I suggest you tweak the text/background values for user entry and calculated results for better contrast in either mode.
                      Roseburg, Oregon
                        Thank you Sable for checking it out. I totally agree with you. Added some new features but the came with a design cost
                        Wil fix it in the comming days.
                        Thanks again!
