Re: Dough isn't crispy
If your sauce is too thin then your dough will have a hard time crisping up.
You pizza also looks too thick, I have great results stretching 250g doughs to 12 inch pies.
Your fire will heat the cooking floor better if you push it to the side instead of the back. This has to do with the way the natural convection pattern works in the oven.
Lastly, most pizza places re-heat their pizza slices, this makes them crispier. If I have guests over (4-6 people), I'll cook everyone's pizza and then re-heat them for 30 seconds back in the WFO. This way I get to eat WITH my guests too!
finally got my Caputo flour and did the first pizza with it. We were very happy with the results. We paid closer attention to the fire this time, removing a good bit of the ash toward cooking time. We then bumped the fire back up to get that rolling flame and cooked on about an 800 degree hearth. It is a noticably better crust with more flavor and more crispiness. I made the dough 2 days before the bake and do believe that it improves with time to develop in the fridge.
The morels were sooo good!!
I have learned so much here, thanks to you all
2 Photos
You also mentioned a concern about fresh semolina. I wouldn't worry to much about fresh as far as flour goes. That may be part of your problem. If the flour you have is too fresh (ie recently milled) then it will be very starchy without many simple sugars. Flour that has sat around for a few months will have more sugars as the enzymes will have had time to breakdown the starches.
If you add malt or sugar and a little bit of oil to your dough it will certainly brown more, and likely make it crisper.
Bob's Red Mill semolina flour is readily available everywhere I frequent. Health food oriented groceries should have it if your regular grocer does not. I don't think you will find it very time sensitive. They have a store finder on their web site. Weis and Wegmans in SE PA carry Bob's...
Good Luck!
Jay
Thanks so much for all the advice! I am actually having trouble finding semolina flour, believe it or not! I really want to try the it in the next pizza dough batch and I also want to have it on hand for bread. My concern now is when I am able to locate the semolina I'm afraid it may not be very fresh! I will get pictures and post here when I make the next pizzas.
Wow, it is weird to see you write that. If I cook cold (and necessarily longer), in the 600s on the floor, my pizza crust has the consistency of pita bread: tough and chewy, not crackery at all. On the flipside, I find that my crusts are the "driest" and "sharpest" if I cook hot and fast, in the 700s, although not really "crackery" either.Originally posted by splatgirl View PostIME, all other things the same, a cooler oven floor and a longer bake time will make more of a crackery crust.
I wonder what the difference is.
My experimentation hasn't deviated too far from the official Forno Bravo recipe (although I have made several batches in which I dumped a generous helping of Italian seasoning and it is EXTREMELY popular amongst my friends/family).
I'm using "proper" Caputo flour, the big 55lb blue bag. In my experience, unless the floor of my oven is well into the 700s, my pizza doesn't cook fast enough and the dough becomes tough and chewy. If I can keep my floor in the 700s though, I get beautiful cripsy crusts with black blisters on the bottom and irregular black and brown bubble blisters on the cornicione (and it cooks like a laser on popcorn, gotta watch carefully!).
I don't know about other flours, and I didn't read carefully enough to see what flour you're using or whether you qualified "hot" with a number, but if you're using Caputo pizza flour, don't cook your pizza under 700 degrees. Even 650 absolutely sucks for me, it simply ruins my pizza.
Hi everyone! Just coming back to the forum after quite a long hiatus and happened on this thread. Woodswitch...if you want crispy but chewy I would recommend using a more mature dough...say perhaps 2 or 3 days matured in the fridge if you can. In our restaurant we use a dough that has similar hydration to yours and cook them at very high temperatures...650F+...today at lunch I baked a 14 inch pizza in about 90 seconds... and I have used the assoluti flour although I am currently using Occident flour from Conagra mills...during the maturation enzymes break down many of the starches into simple sugars and it seems to me leads to a crisper crust with still a bit of chew...I can hear the crispness when I cut the pies...
Hope this helps!
Dutch
Good comments, splatgirl!
It is really easy to get in the habit of baking pies in one spot in the oven but ovens definitely have cooler and warmer areas and it can be smart to take advantage of that! I do it a lot when doing appetizers but I don't think about it so much with pizza (usually to lift the pizza into the dome for a final burst of heat to caramelize the crust/toppings some more). I hadn't thought about pulling a pizza into the mouth of the oven to prolong slower cooking for a crisper crust but that's a good idea. (If not heavily heat loaded my bottom insulated oven varies more in temp than the top insulated ones seem to so I know the effect, just hadn't used the variation to advantage!
Good thoughts!
Jay
IME, all other things the same, a cooler oven floor and a longer bake time will make more of a crackery crust. You could also try lowering the dough hydration, kneading the dough more, or both. Back when I first started, I could get crispy and crunchy without even trying. What I did then would be what I would call overkneading and overhandling now.
As Jay says, rest assured you will get a sourdough starter going with patience and persistence. Putting a raisin in the flour/water slurry was the trick that worked for me.
Hi WW!
Your description is a big help! Toppings are also important. It is really hard to make a crisp, thin crust with wet toppings - they soak the crust too fast. So a little oil can be beneficial to help keep the dough "dry" (try misting the dough with oil or putting oil on the pizza first as an alternative or augmentation to) putting oil in the dough). I would like to see a photo of the pie too (top and bottom) if possible next time for that would tell me a lot. Your description leads me to suspect toppings are an issue. try making a Caramelized onion, blue cheese, walnut pizza (Reinhart, American Pie). That should be really crisp (or can be). If you can't make the crust you want with that pizza, then lots of things need to be considered. If it is great, then it may well be more about the toppings. I personally also find that bread flour gives me a reliably more crispy crust than AP.
I am intrigued that the pie you had at the pizzaria is so different from the one you make from the same flour....
The proofing is NOT the problem.
You will get sourdough starter. But it will probably come from the flour and not the air. You will probably have major activity on day 2 or 3 and will think it is good and it is bacteria. They will drop the pH of the starter until the acid stops them (about a day) and then your starter will appear dead until the yeast you want multiplies enough to take over (up to a week or more into the process). Just feed it at least once a day or so until it starts showing activity the second time. Then move to twice a day until it seems healthy and vigorous. You shouldn't expect to bake with it for at least two weeks. And keep it on the counter until then! Once it is vigorous and doubling every 8 to twelve hours you can safely begin refrigerating it.
Good luck isn't really necessary. Perseverence is. You will get there! It is amazing how many people throw the starter out on day 4 or 5 thinking it is dead and it is just getting going! Using pineapple juice doesn't really accelerate the process much but it does avoid the initial blast of bacterial growth.
So...Hang in there! It WILL happen!
Jay
Thanks so much for the recipe! I will try it and let you know how it comes out.
I use 20% (of the flour component) of semolina and it gives a very nice crunchy consistency. My normal (meaning the last one I did, it changes a little every time) was:
590g KABF
205g semolina
690g water
1 Teaspoon sea salt
1 Teaspoon of turbino sugar
28g ADY
edit- I guess I should tell you the prep:
I mix the ADY in one cup of warm water with 1 teaspoon of turbino sugar for around 20 minutes.
I dry mix everything else, then add the yeast-water, then add more water until it is the consistency I like (690G TOTAL including the yeast water in this instance). I stir vigorously in the bowl with a wood spoon for around 3 minutes, then let it double for a couple hours.
After doubling, I fold it around 8 times on a well floured counter, then form a big ball which I cut into 4 equal size pieces which I ball and place in lightly oiled tupperware for use the next day (or 3rd or 4th day). Each ball makes a 14" pie at the thickness shown.2 PhotosLast edited by Tscarborough; 10-06-2010, 07:48 AM.
