I thought this was useful.
https://www.youtube.com/watch?time_c...&v=vV4gegZ7JNU
Common Mistakes, Pizza Disasters
This is a sticky topic.
Pizza party, 30 pizzas to make. Plan is for me to tend the fire, drink beer, keep the guests amused and cook. Friends are making the pizzas in the kitchen. They are already? Are we starting? Hell...
First one on a wooden pizza peel has more flour on the peel than was in the pizza. It almost exploded when I slid it into the oven. 'Less flour!' is the call. Nothing appears for half a beer, so I go to see how they are doing. It's bedlam. No room to move and the next one has been made directly on the work surface with zero flour. Took us a few minutes to scrape it off and turn it into a calzone. The third is being rolled out with a pin to the thickness of a few microns. Ditto no flour. Ah well...
Lesson learnt: Make sure everyone knows what they are doing and how to do it before you start. That should include yourself. I'd made around 7 or 8 pizzas myself up to this point and here we go making thirty in one hit. Well, it was fun. Stressful but fun. And the pizzas tasted great.
Re: Common Mistakes, Pizza Disasters
I don't have a wooden peel, just use aluminium and if you 'lubricate' whatever peel you are using with semolina or your preferred medium then they will release the same.
Timber has a traditional ring but I am sure that those who pioneered WFO's could have got their hands on a bit of stainless or alumina they would have embraced that.
All about personal preferences and how much theatre you want.
I do not own a wood peel, never have. I have the one shown above, but slotted, and a small turning peel. The metal slotted peel is superior, IMO.
I personally think everyone should own two different peels. One wooden for building and launching pies into the oven and another, metal banjo style for turning and removing pies form the oven. The wood is the best way to go to keep from having a pie get stuck, just make sure to lubricate it with semolina and not let it sit too long before going into the oven.
When it comes to pizza not sticking on peel which peel is recommended - wooden or Aluminum.
Would this be a good choice: Pizza Peel: Professional Aluminum 13-inch Rectangular, 20-inch Handle
Any good wooden peels suggested
Originally posted by james View PostStep back from the pizza tray! Please don't use a tray. :-)
Just keep practicing using enough flour on your pizza peel. Cooking pizza directly on the floor is the only way to go. It's the best part.
What type of peel are you using, and what are you using to keep your pizzas from sticking?
Friends don't let friends load pizzas into their ovens with yard signs
Originally posted by GianniFocaccia View PostThen there's this little tool, which can accommodate 2-3" depth of toppings, not to mention a hamburger, loaded fries, whatever
https://www.youtube.com/watch?v=PaoAsvI-xLQThat's a yard sign.
Friends don't let friends load pizzas into their ovens with yard signs.
Not sure what you call it, but I have a tool that looks like an elongated cake server that I slide under the raw pizza to loosen it off of the peel. As I slide the peel in the oven, I give a little lift to the pizza so that it slips off of the peel much easier. Works very well even for those heavy over loaded pizzas. Not sure if I am explaining it that well so I might need to make a little video of this technique.
Thread needs a bump.
I was cooking for a large group who were preparing their own pizza's with some direction from one experienced pie maker. All was well until a good friend of mine brought out his second pizza and he had loaded it up about 2" deep in the middle. All night we had been preaching to keep the pizza's lightly topped, but this guy is a big guy and he said to me, " I like my pizza loaded"
I knew what I should have done, but I was just the cook, not the host so I dutifully put it in. 1. wouldn't slide off the peel, way to top heavy and sat on the peel while he piled it on. 2. Oven was cooling off a bit, we had been through about 25 pies by then and I was keeping a good fire going, but it had cooled off some. 3. couldn't turn, I had to do the half flip cause the center was still soft and doughy.
He ended up with an under cooked calzone which he happily devoured, and I learned to just say no when a pie is going to ruin my oven floor. I had to stop cooking and rake coals over the mess to get the floor back into shape for more pies. It took about 10 minutes, and no one was really upset, but I kicked myself for not knowing better. If that had happened in the first ten minutes, it would have been a long night with a sticky floor.
I have a saying I tell everyone. If the pie won't shake on the peel, it ain't going into the oven.
If you're really trying to crank out pizzas fast (around 2 mins) I've found you really need two people prepping and one at the oven.To roll the dough and prep a pizza in 90 secs is pretty hard. Having two people working at it ensures you always have a pizza ready to cook. I usually manage the oven, dress, cut and plate the pizzas. If your oven is large enough to cook more than one pizza at a time then you may need three people prepping to get them out fast.
I did many small pizza bakes and they came out great. Then I got cocky and tried to do 20 pizzas for my neighbors Super Bowl gathering (he paid for all the stuff).
I had a great pattern for making the the pizzas then putting them on the peel and sliding them into the oven. Except for the one that I did a little differently and move left when I should had stayed still and the raw pizza hit the dirt face down with everyone watching.
No excuses. Once you have set up an assembly line, do not break the pattern. Just keep doing the same thing over and over and all should go well.
Also, Have 2 peels. If one gets sticky or gets some sauce on it, you can give it to a bystander to clean. It gets them involved and keeps the whole thing going.
If I could have it my way, I would have one person making the pizzas and I would be at the oven. The through put would increase by 100% - better pizzas faster.
Instead of flour, use semolina, but not too much as it burns and would taint the pizza!
Bearing like tiny ball bearings, it is easy to get the pizza off the peel
Graham
Originally posted by daryls View PostThat happens to me all the time, toppings falling off the dough when inserting the peel in the forgo. Easy solution was to cook dough only for 1 minute and then add toppings. Works like a charm every time.
