"00" Flour
  • "00" Flour
    Is there a big difference between Caputo "00" Blue and Caputo "00" Pizzeria flours???
    Cricket
    Re: "00" Flour
    Not a lot. The pizzaria flour has a slightly higher protein content. They are both heat tolerant for wood fired oven use. They both make a smooth and extensible skin.
    As an experiment I made a pizza skin from AP flour with a little whole wheat. The texture was quite different, but the big change was that the spots with char just had a burnt taste instead of that dark intense flavor you get with the Caputo flours.
      Re: "00" Flour
      Dmun,
      Thanks for the info. Unfortunately the only oven I have is a conventional one which only goes to 550 degrees. I use a pizza stone on the very bottom floor.
      Cricket
