Pizza Dough - moisture problem
  • Pizza Dough - moisture problem
    I store my dough in plastic tubs with lids (for use on the same day). Often times a lot of moisture builds up inside the tub and then the tops of the dough balls form a crust. The botton is perfectuly silky. Suggestions on how to either keep the moisture out or off the dough?
    Re: Pizza Dough - moisture problem
    Could chill the container...that might cut down on some of the moisture
    Best
    Dutch
      spray a little oil on the top of the dough balls
      My thread:
      My costs:
      My pics:
        Oil the bottom of the container, then lightly oil plastic wrap and put over dough, not completely removing the dough from room of refrigerator air...this will keep the moisture off..
          I like the last suggestion. Keep as much air away from the dough as you can. The less air in the proofing tray or bowl, the less skin you get. Nasty stuff, huh?
          GJBingham
