hi, i am having a hard time cooking in my primavera 70. i want to list my problem and possible reasons ,hopefully someone can help rule out certain items, so i can cook a constant pizza.
i fire my oven hot trying to do a pizza in under 90 seconds,850 deg floor top about the same . my pizzas burn before the dough sets enough to turn it. i use caputo flour at 60 % hydration salt and yeast. the oven interior is only 28 inches so the pizza sits within four inches of the flame. also, my stand allows water to get under the oven ,which pours out of a hole under the floor, this water get very warm and i am wondering if it is allowing steam to build up and absorbing into the oven floor. am i cooking to hot? and to close to the flame? i had better success when the oven was newer . i should be getting better not worse. i am going to go for a 750 deg floor and top tonight to see if i have better luck. can any one tell me if that 850 range is realistic or wether the water under the floor may be a cause. i am very happy with my oven but experimenting with higher temp has me frustrated thank for any help. larry
