Autolyse 101
  • heliman
    • Sep 2009
    • 1181
    Autolyse 101
    Another thread highlghted the critical nature of the Autolyse process in pizza making so I thought it would be worth discussing this under a separate thread.
    Specific questions so far:
    1. The FB recipe talks of an autolyse time of 20 minutes but others have suggested 30 minutes. Any preference?
    2. Does the autolyse have to take place with flour and water only - or can the salt and the instant dry yeast be added with other ingredients before autolyse takes place?
    3. What percent of the recipe flour needs to be added to the mix to make the autolyse most effective. The FB recipe suggests 80% but I have heard 65 - 75%.
    Any thoughts or suggestions appreciated.
    Rossco
    / Rossco
  • DrakeRemoray
    • Mar 2006
    • 1215
    Re: Autolyse 101
    Personally, for all bread and pizza making, I add all my flour, water and yeast, then I do a brief knead, autolyse for 20 minutes then add salt and finish kneading...
    My Oven Thread:
    • heliman
      • Sep 2009
      • 1181
      Re: Autolyse 101
      I have been adding all ingredients before autolyse but last night went flour and water only - and left it for 30 minutes. I made the dough balls and they are now sitting in the fridge awaiting a baking session this evening.
      Observations so far are that the balls have maintained their shape much better than before. Previously with all ingredients added to the mix before autolyse the balls puffed up and even overflowed from the container. Using the same amount of yeast this hasn't happened with the latest batch.
      I will provide an update on the final shaping and cooking process after the session this evening as I will have a better idea of the overall results. So far however I am quite impressed...
      Rossco
      / Rossco
      • FrankF
        • Jul 2009
        • 11
        Re: Autolyse 101
        I've noticed a difference in the e-books for WFO's and Pizza stones. The WFO e-book calls for 80% of the flour for autolysing while the pizza stone e-book says to put all in all the flour. Both call for holding off on the salt and yeast till after autolysing is complete. I've been following the pizza stone version in my WFO with excellent results. Helps to use Catputo flour if you can get it. Just my 2 cents.
        Frank
        • heliman
          • Sep 2009
          • 1181
          Re: Autolyse 101
          Yes, I also went with the 100% flour, added in two stages about a minute apart. I added the salt and yeast together as well. The result was the very best dough I have made so far.
          I went with Dino's suggestion of 2 grams yeast (instead of 3). I was very pleased with the results at this evenings bake-off. Nice crusty, crispy result and the dough stretched very easily with no weak/thin spots at all.
          Can't wait to crank the WFO up at the weekend...
          Rossco
          / Rossco
          • Mitchamus
            • Aug 2008
            • 389
            Re: Autolyse 101
            I normally dissolve the yeast in the water with a pinch of brown sugar to get it moving... (and to make sure the yeast is ok)
            so until now, my autolyse has included the yeast, but I'll try water only the next time.
            really - you need to do two batches side by side at the same time to campare methods properly, as temperature & relative humidity could be skewing your results
            My 2nd Build:
            Is here
            • heliman
              • Sep 2009
              • 1181
              Re: Autolyse 101
              Thanks Mitch ....
              Think I may do a few batches this weekend (simultaneously) on a scaled back recipe which produces 2 x pizzas..
              The last batch was just incredible I have to say and I attribute the success largely to the use of the "padddle" attachment on the KA at the beginning of the process, then switching to the hook after autolyse.
              Doing a quick batch this evening to see if I can duplicate the results of the last batch .... here's hoping ...
              Rossco
              / Rossco
              • heliman
                • Sep 2009
                • 1181
                Re: Autolyse 101
                I have a quick question on autolyse...
                I understand that different flours absorb water differently. In making dough with say 65% hydration, one calculates the 65% water/flour ratio accordingly. The question I have however is how can one check to determine if the flour/dough is actually 65% hydrated. I know there are adjustments to be made for temperature etc. so perhaps this is also a factor at this stage of the process.
                What made me think about this was when I watched the FB dough preparation video again and I saw how floppy that dough was. I would think that mine may need more water ... or could that be kneading to get the floppiness??
                Hope my question is clear enough..
                TIA
                Rossco
                / Rossco
                • Mitchamus
                  • Aug 2008
                  • 389
                  Re: Autolyse 101
                  Since you are using a KA to do the kneading,
                  I doubt that it's due to a lack of it!
                  Although the recipe says 65% hydration, it also says to add enough flour till it just forms a dough ball. - the final result may be higher than 65%.
                  Since you are experimenting - have you tried the no knead method yet?
                  put everything in a bowl, mix it up a bit, and leave it on the bench over night.
                  In the morning, punch down & make up your dough balls, let them sit for a at least 30 mins before using - or store in the fridge till you ready. (snaplocks!) again allow 30 mins or longer to get to room temp (maybe an hour?)
                  My 2nd Build:
                  Is here
                  • Mitchamus
                    • Aug 2008
                    • 389
                    Re: Autolyse 101
                    go on try it!
                    In the time it takes you to reply, you could have made a batch! :P
                    My 2nd Build:
                    Is here
                    • texassourdough
                      • Nov 2006
                      • 1719
                      Re: Autolyse 101
                      Hi Rossco!
                      There is no way to tell what the precise hydration is. The closest you can reasonably get would be to live in a very dry place like Arizona or most of Australia and let the flour really dry out. Then the hydration calcs will be reasonably correct for simple doughs of water, flour, and salt.
                      One can dry the flour in a laboratory to measure the water content, but...it's not practical at home.
                      My favorite pizzaria uses Caputo and during a recent wet period was mixing at 58% hydration to get the same dough texture they normally get at 65. (That seems extreme and likely to involve more than flour hydrtion but???)
                      In calculating hydrtion milk is treated as water. Oil doesn't count. It is all approximate - at best.
                      Jay
