Pizza with Biga
  • Pizza with Biga
    I found this biga based dough recipe quite good so though that I would share it with others for their comment. I am making the biga tonight for use with pizza dough tomorrow. The resulting pizza dough had a subtle sweetness to it which I found quite pleasant. I would be interested in getting feedback on this or any other biga based recipes for pizza making.
    Rossco
    Footnote
    I created the biga component using BBA methodology (P107) and upscaled the percentage to my required dough size.
    / Rossco
    Re: Pizza with Biga
    how many pies does the 5qt recipe make and would you do it again?
      Re: Pizza with Biga
      Latest variation and current recipe.
      Biga
      Flour 99.9 - 100.0%
      Yeast 0.1 - 0.1%
      Water 60.0 - 60.0%
      Main batch
      Flour 391.4 - 100.0%
      Water 234.9 - 60.0%
      Salt 10.8 - 2.8%
      Starter 156.6 - 40.0%
      Olive Oil 16.4 - 4.2%
      Makes 810 grams.
      / Rossco
        Re: Pizza with Biga
        Hi Rossco!
        Are you using AP or bread flour? If it is the subtle sweetness you are like, you might want to run an experiment and treat the biga as a soaker - simply mis the flour with water and let sit overnight. That way the enzymes will make sugar but there won't be much going on to consume the sugar until you introduce the yeast. It would make an interesting head to head comparison.
        Jay
          Re: Pizza with Biga
          Hello Jay ....
          Back at work yesterday so brain is not working too well....
          I am using "Superb" Baker's Flour - a high gluten flour used by a number of the local pizzerias here.
          Sounds like an excellent experiment - will give it a go. Not familiar with that process though - sounds interesting.
          On another matter - I am sifting through pics and stuff of the holiday and hope to be able to provide a summary of the pizza experience during Italian tour. There was so much to consider and it has really altered my thinking considerably. Most notable was the da Michele pizza texture - completely different to what I expected. I am wondering now if that is the "benchmark" to aim for or if I should continue making them as I like them and experiment accordingly....
          PS: Just heard that I am on track to be "doctored" this Friday!
          / Rossco
            Re: Pizza with Biga
            Hi Rossco!
            Hang in there! Having only become Dr. Jay in February I am well familiar with the feeling... Baking will be a good way of using your time in the interim...
            Soakers are used a lot in whole grain bread additives to prepare the grains (cracked wheat, oatmeal, whatever) so it won't absorb water from the dough during proofing. Reinhart uses soakers a lot in his whole gran bread book but goes beyond the additives, sometimes doing flour as well. It seems to be a neat trick to build flavor and supercharge the yeast. The bacteria will do a little overnight but the enzymes will create a fair amount of sugar which can accelerate the yeast the next day. And in my experience the bread often shows just a small touch of sweetness from having a bit more sugar in the final bread (that may be hallucination - look forward to your thought!) All you need to do is take your preferment flour/biga and not add the yeast. If you do it both ways simultaneously, the soaker based dough should need a little more room temp time (probably an hour or so) to catch up with the biga based dough. (Assuming both get retarded in the fridge for a while before being pulled to warm up and relax before baking.)
            The reason I asked about the flour is your hydration is pretty low. You compensate by adding olive oil. Nothing wrong with that, I like oil in BF pizza dough also for it softens the potential toughness of BF dough.
            Look forward to hearing of success on Friday!
            Jay
              Re: Pizza with Biga
              Someone just lent me a stack of bread books, including all the Reinhart ones, so I'm looking forward to trying a few of these pizza dough techniques.
              My Clay Oven build:
              http://www.fornobravo.com/forum/f43/...dah-12821.html
                Re: Pizza with Biga
                Peter doesn't use a soaker, or as I recall a biga, in any of his pizza dough recipes. He just does the retard. There will be nothing wrong with doing a soaker, however. Peter's normal pizza dough timeline is 8 to 24 hours with (basically) a refrigerator retard beginning 0 to 30 minutes after completing the mixing or balling of the dough (depending on the specific dough). IF you want to try the soaker approach you would want to begin that 6 to 12 hours before the mixing stage in order to provide enough time for the ezymes to do their thing and impact flavor. If you go much longer you will tend to lose dough strength.
                The flour soak can be used on most any recipe. (Assuming a conventional one step mixed bread) Just subtract the water and flour in the soaker from the recipe amounts and mix it all up the next day. For bread you probably don't want to use more than about 50% soaker (i.e. half the flour in the soaker and half added dry in the mixing step) because of the loss of strength. For pizza dough that shouldn't be as critical. One could try mixing the water and flour early and only adding the salt and yeast at the mixing point. (I haven't tried that but it shouldn't cause any problems for pizza though the dough may be a bit sticky.)
                Good luck!
                Jay
                  Re: Pizza with Biga
                  Hello Jay,
                  Apologies for the delay in responding - things have been very hectic here of late. Our neighbour passed away earlier in the week from cancer so there was a funeral and some other activities to deal with there. Also, the PhD was conferred yesterday - yes, finally!
                  Keen to explore the soaker approach and I will probably get pizza activities going again by next week. Going out to a restaurant this evening and will be having a "pizza free" bash on Sunday (making them curry & rice) to celebrate the doctoring in the meantime.
                  Dr Rossco
                  / Rossco
                    Re: Pizza with Biga
                    Congrats on the PhD Rossco.
                    I've been trying to get hold of the Superb flour here in Brisbane, after reading your good reports on it - haven't had a reply from my email to the manufacturer yet.
                    Just been reading BBA tonight - lots to take in!
                    Cheers,
                    Mick
                    My Clay Oven build:
                      Re: Pizza with Biga
                      Ack... somehow my response disappeared!
                      Congratulations, Rocssco!
                      I was waiting to hear from you regarding the award...
                      Enjoy!
                      Dr. Jay
                        Re: Pizza with Biga
                        Thanks Mick...
                        I seem to recall that the manufacturer took a while to get back to me.
                        Maybe worth dropping Ron at Variety Foods here in Perth a note as I am sure he will know who the Brisbane outlet is for Superb Baker's Flour. A quick google will provide the email address...
                        / Rossco
                          Re: Pizza with Biga
                          Thanks for the good wishes Doctor Jay!
                          / Rossco
                            Re: Pizza with Biga
                            Hi guys,
                            I came on this thread via the search box. Rossco has a Ph.D., Jay has a Ph.D., I'm going to have a Ph.D. in December. How many doctors does this forum have!? Is there a statistical correlation between higher education and wood oven cookery?
                            Candidate Stan
                              Re: Pizza with Biga
                              Good question Stan! I think it probably has more to do with innate bullheaded stupidity and the stickatitiveness that the doctoral process develops. And...it's probably a guy thing sort of like "Dancing with Fire". Plus, there is the timing factor. Working on a doctorate takes years. A pizza, only about a minute. So we really appreciate the "speed" reward.
                              Good luck with your diss! Fun, fun, fun... (NOT!)
                              Jay
