Inner arch dimensions
  • pizzahead
    • May 2008
    • 62
    Hi.
    I am building a new 1000mm (42") wood fired oven and have a question about the size of the inner arch opening. I am currently planning it to be 520mm (21.6") wide. My previous oven was 480mm (20") but I would like the extra space to get things in and out.
    Any advice would be really appreciated.
    Jase
  • mrchipster
    • Apr 2010
    • 1502
    Re: Inner arch dimensions
    Originally posted by pizzahead
    Hi.
    Jase
    Mine is 21.5 inches wide and 13.5 inches tall with a 10 inch flue and 42 inch diameter oven, hemispherical entry. Breathes very well no smoke out the entry. I think you are right on target.
    Chip
    Chip
    • pizzahead
      • May 2008
      • 62
      Thanks Chip.
      I set up the arch last night and had a look. I reckon it is a bit too large so have pulled it back in size a wee bit.
      I think it will still retain heat well and also draw nicely.
      Fingers crossed.
      Jase
        • 2848
        Gudday
        You could always use a blast door to retain the heat while the fire in the oven and keep the entrance big
        Regards Dave
        • Mike D
          • Oct 2010
          • 342
          Just make sure that the entry is far enough into the dome so you don't end up with a teardrop. Draw it up, make a couple of cardboard cut outs. Once you start it you have to roll with how the build progresses.
          Mike
          • david lyons
            • Nov 2010
            • 19
            Hi,
            I am at the same stage of trying to get my mind around the entry arch.
            I presume that the inner end of the entry arch bricks actually reach into the oven slightly at the base. Also how important is blending the inner top of the arch, does this affect smoke flow significantly or not? My guess is that some intrusion at the base would tend to direct exhaust gases upwards?
            Dave Ly
            • mrchipster
              • Apr 2010
              • 1502
              Originally posted by david lyons
              Hi,
              Dave Ly
              Read the post "Octoforno" I believe this is one of the better ways to build an inner arch. My post "Chip's 42 in Minnesota" also follows this technique and it makes for a much easier transition dome to inner arch.
              Several others have used this technique and credit goes to those who developed it.
              Chip
              Chip
              • david lyons
                • Nov 2010
                • 19
                Hi Chip,
                Thanks muchly for the direction, that is information I knew would be in here somewhere but old farts like me find it daunting to find the way around these sites at first.
                Regards
                Dave Ly
