Hello Everyone,
After months of research and saying I want to build a WFO, I finally started this weekend. I have attached a few photos and plan on pouring the supporting slab in the next few weeks. But was wondering if I need any extra support in the middle(The opening is 1380 x 1380) I am worried about the concrete staying suspended with the weight of a 42" oven, when following the plans downloaded from the FB website. I also need to know about mixing vermicrete at the 5:1 ratio if that is straight Portland Cement or do you need sand and aggregate. Any other suggestions or things to watch out for will be helpful. The second open area is about 600mm wide and I have a prefab stainless steal bench that will be fixed there.
Thanks in advance for your time and help,
John
John
its all the same.
