Re: Bacterium's 2nd build
Mark the center line of the arch then 38mm from each side of the center line, this will give you the top (keystone brick, although they are all keystones) 10mm each side for a joint, 75 per brick each side etc, etc, etc.
Edit:- Looking at your pic you need to get rid of 40mm to make it all work.
