Bacterium's 2nd build
  • Bacterium
    • Apr 2007
    • 560
    #106
    Re: Bacterium's 2nd build
    Fought the rain and got my flue in last night..it was getting late but I went for broke and did a small paper and cardboard fire to celebrate..........wife was laughing.......but I was stoked!!!!!!
    Ugghh smartphone won't let me load the pic...
    Cheers
    Damon
    Build #1
    Build #2 (Current)
    • Bacterium
      • Apr 2007
      • 560
      #107
      2nd fire tonight.....pic is of fire last night
      Cheers
      Damon
      Build #1
      Build #2 (Current)
        • 5261
        #108
        On the home stretch, nothing like a fire to know you are almost there.
        • Wayne73
          • Oct 2012
          • 133
          #109
          Great stuff Damon, get out the marsh mallows.
          My build. http://www.fornobravo.com/forum/f51/...ton-18665.html
          • Bacterium
            • Apr 2007
            • 560
            #110
            thanks guys.....
            yeah the kids mentioned marshmallows, good idea.....think I better do it for next fire.
            Cheers
            Damon
            Build #1
            Build #2 (Current)
            • Cookie Monster
              • Nov 2011
              • 56
              #111
              Great work Damo it looks really good!!
              Congratulations on the first fire... I am not too far behind...
              • Bacterium
                • Apr 2007
                • 560
                #112
                thanks guys...... Russell I remember when we were at a similar phase......then my progress dropped off completely.
                here's pics of my flue install. The dektite (roof gasket/seal thingy) bottom edge pulled up about 100mm above the bottom of the corrugated sheet.... cool!!
                Under the eave, typically the ceiling box (black bit) should be toward the top and there should be the stainless inner flue exposed for the first bit......but it would probably look odd with only 100-200mm (up to 8inches) of stainless flue showing
                triple wall flues are really quite large....then again oven is technically a 45inch oven so meh.... least its a safe design!!!.....
                Cheers
                Damon
                Build #1
                Build #2 (Current)
                • oasiscdm
                  • Jan 2012
                  • 1239
                  #113
                  Well done Damon.
                  nice photo's that is double skin isn't I am assuming 8/10", If this is the case your anchor plate only allowed for one skin how did you attach the second skin.
                  Hey damon - i'm organizing a quote for the flue Russell used from the UK. I'm guessing there wont be any change out of around $700-800 after delivery.
                  Cheers Colin
                  Oven 1 Completed
                  Oven 1 and surrounds
                  • Wayne73
                    • Oct 2012
                    • 133
                    #114
                    Hi Damon, looking good. Whats the reason that the flue is so long? Is it for draw or somthing else?
                    • Bacterium
                      • Apr 2007
                      • 560
                      #115
                      Guys it was cheaper to buy the kit and ditch what I didn't need.
                      Yes it's an 8 inch (205mm) inner stainless, then a 9.8inch(250mm) galv. then another 11inch (300mm) galv. on the outside.
                      The flue box (start of outer skin) just sits on top of the brick square, which the spigot plate sits inside.
                      The bottom of the flue box is a flat section, so inside this sits/starts the second skin
                      Then obviously the inner flue inside that.
                      Normally the flue box is only 300mm below ceiling but I took it all the way down as seeing only 200mm of stainless flue (inner) wouldn't look right.
                      Overall height puts it above my ridge line and into the breeze. Did my first full fire today and outer flue skin was still ambient......happy with that.
                      Managed to sneak in a couple pizzas and a cake later on. Without insulation it's understandably slow heat wise.
                      I managed to keep all the brick cutting slush/ dust which gets left in the brick saw tray. Was thinking of adding this to the dome to give it more thermal mass.
                      Do I just mix it (3) with sand(1), cement(1) and lime(1) or would I need fire clay as well?
                      Cheers
                      Damon
                      Build #1
                      Build #2 (Current)
                      • Wayne73
                        • Oct 2012
                        • 133
                        #116
                        I think some People use the brick dust as fire clay
                          • 2848
                          #117
                          Gudday
                          Fireclay is unfired so a different beastie. The fireclay or brickies clay is added to the mix to make it more user friendly ie sticks the the brick better you can sqish the brick a little without breaking the bond. Ground brick would be like adding more aggregate ie sand.
                            Good points Wayne and Dave,
                            I screened my cuttings through a window screen. And as you say there were sand sized brick chips in the mix. But, there was still plenty of dust. I ended up replacing 1 part of the sand with 1 more part brick dust. That was for making the "home brew". Since Damon is wanting to add extra thermal mass, the larger particles would help add some aggregate for a refractory concrete. I did not do that so maybe someone else will step in for the right formula. I know that Tu did something like this. What about it Tu?. Any others?
                            • Bacterium
                              • Apr 2007
                              • 560
                              #119
                              Ouch....
                              The crack fairy visited last night.....looks just hairline about halfway up at the back....but then it worked its way down to dome base.
                              O well doing a layer directly over the dome bricks might be a wise thing after all.
                              Cheers
                              Damon
                              Build #1
                              Build #2 (Current)
                              • Wayne73
                                • Oct 2012
                                • 133
                                #120
                                that sux man! is the crack in th brick or the mortar?
