G'day all,
I've finally started on my Argentinean style parrilla bbq and oven. My take on this simple but effective wood fired grill is to have a firebox area in the lower left, that heats up a little oven box created out of firebrick slabs straight above it (upper left). Hopefully it will heat this little box up enough to do bread, spuds, empanadas etc, and maybe even pizza if i'm lucky. But the main idea is for the fire to create white hot coals that are spread under a moveable grill which takes up the whole right hand side, to slow cook meats of all kinds. There is a short dividing wall between the two to keep ash etc away from the food on the grill.
I've had the pros in to lay the blocks properly (given it is 3.6m tall and will be supporting both a patio and shed roof eventually), and now i'm doing the rest myself. I poured the concrete slab benches, and have installed the galvanised hood inside the blockwork, which will have an 1800mm long, 200mm diameter flue attached which will poke through the tin roof that will go on top (cowl height will be a whopping 4.5m off ground to get good draw and hopefully no complaints from any neighbours about smoke!?).
