Wood to burn
  • nissanneill
    • Apr 2007
    • 1886
    Wood to burn
    Been giving my son a bit of help with a problem gum tree on his new house property in the Adelaide hills. After a couple of days of bad weather and a couple of tree monkeys, it finally came down with probably 20 tons of wood BUT the 3 big logs will be milled to build staircase, decking and outdoor furniture (once dried). However there is plenty of wood which will not go to waste and will end up in my Pompeii.
    Neill’s Pompeiii #1
    Neill’s kitchen underway
  • BOOMERS WFO
    • Apr 2012
    • 113
    Re: Wood to burn
    Wow Neill,
    That was certainly a bigun. Look forward to seeing the cured milled wood in a future furniture.
    Glad it didnt fall on anyone. Ouch!!!
    Craig
    "All I ask is the chance to prove that money can't make me happy"
    Spike Milligan
    "It is only impossible if you stop and think about it"
    The Pirate Captain
    • heliman
      • Sep 2009
      • 1181
      Re: Wood to burn
      Great - you should have a solid supply for the next 3 years or so!! :-)
      / Rossco
      • nissanneill
        • Apr 2007
        • 1886
        Re: Wood to burn
        Had a busy week-end slabbing and planking the 3 logs, what a load of great boards, and a wide variety of plank sizes and one log slabbed.
        This green timber is unbelievably heavy and as the day got longer, my strength diminished considerably.
        We cut plenty of 10 x 2", 10 x 5" and 4" slabs (which we had to cut in halves to manually handle or the 6m long ones were towed off with vehicles and chains.
        Also, as a result there is a huge amount of sawdust (with a 6.1mm kerf from the 10" Lucas portable mill) and a huge amount of offcuts, several years supply for me.
        The staircase step treads were shrink wrapped to slow down the moisture loss as will the slabs which will take a couple of years to dry.
        These mobile sawmills are incredible, my son and I could not keep up with my cousin who was operating his new toy. The step treads (10" x 5" x 48") for example weighed in at around 50-60kg At the end of the day, even the offcuts and waste wood was too heavy to lift but had to be cut down into "more manageable sizes"! Guss I'm showing my age eh!
        Neill’s Pompeiii #1
        • nissanneill
          • Apr 2007
          • 1886
          Re: Wood to burn
          Just a few more pics.
          Neill’s Pompeiii #1
