I am using CSR Bradford Fibertex 650 ceramic blanket for the insulation of my dome. It is 50 mm (2 inch) thick. When I completed the dome, I found that the original bag of insulation was not quite enough to cover the dome, so I had to order and extra one. Since getting the last bag, they have made changes to the manufacturing and the new one is wider and longer with foil backing, so now I have lots of blanket.
I was thinking that I will now have enough to do 2 layers of blanket -meaning an insulating layer of 100mm(4inch). The newer over the older held with wire & chicken mesh
If I go this path, do I still put a thin layer of vermiculite/cement over this before the render of the dome? Or do I just render over the blanket? I probably wont have a lot of room at the base of the dome to the edge of the hearth slab to go too thick on top of the blanket.
The dome will be exposed to weather. I would rather over engineer than go back and redo later.
I have used the waiting time for the blanket to cure my oven. Post to follow.
Craig
Craig
some don't
