Wood fired oven corner build in Grafton NSW
  • Wayne73
    • Oct 2012
    • 133
    #106
    Re: Wood fired oven corner build in Grafton NSW
    Ok so I redid the outer arch.. long story short I wanted a "heat break" inbetween the outer arch and the dome and it wasn't going to work the way I was building it.
    This also ment sacrificing the entry arch.
    My build. http://www.fornobravo.com/forum/f51/...ton-18665.html
    • mrchipster
      • Apr 2010
      • 1502
      #107
      Sweet looking work. You will be very happy with that oven.
      Chip
      Chip
      • Wayne73
        • Oct 2012
        • 133
        #108
        Originally posted by mrchipster
        I have a 42 inch oven with a 10 inch and it burns nicely. No smoke in my face and heats easily within 90 minutes to pizza temps.
        Chip
        Thanks for your imput Chip, Its about 2 meters from arch to the ceiling, do you know if length make any difference with the flue diameter?
        • Wayne73
          • Oct 2012
          • 133
          #109
          Finished !!! ...the brickwork anyway.
          I've added some decorative bricks to brake the front up a bit and I have them hanging an inch or so lower then the outer arch as I plan on adding a "smoke brake".
          I've got my insulation ready to go.
          Then the plan is to box it up with metal frame,blue board and then render.But I need to work out the flue first.
          • reccymech
            • May 2013
            • 20
            #110
            Great job WayneO.
            Just a question as to your 'slab' under your brickwork. What's the measurement? Reason I ask is that I've poured a 100mm thick slab around part of my home and where I'm going to build the outdoor BBQ & WFO I negleted to 'add' extra measurement.
            So, where I have to build the slab will be 100mm, is this thick enough? I don't wish to 'cut' up a portion of slab to pour a thicker slab. My area is big enough for a 44" WFO, so that's what I'm going to build (hopefully).
            • Wayne73
              • Oct 2012
              • 133
              #111
              Yeah Its just a standard slab 100 mm all the way though no extra thickness or footings.
              • reccymech
                • May 2013
                • 20
                #112
                Cheers.
                Not to hijack your thread as I don't have a build thread (yet).
                • Wayne73
                  • Oct 2012
                  • 133
                  #113
                  No worries, If you not wanting to hijack you could always send a pm.
                  • Wayne73
                    • Oct 2012
                    • 133
                    #114
                    Progress ...
                    Hebel blocks make life easy.
                    Perlite for insulation Ive added five 100 ltr bags and i will need at lest two more.
                    • mrchipster
                      • Apr 2010
                      • 1502
                      #115
                      You do very nice work, worthy of other to follow in the future.
                      Chip
                      Chip
                      • Wayne73
                        • Oct 2012
                        • 133
                        #116
                        thanks Chip.
                          • 5260
                          #117
                          A shame to hide your fine looking doom. Nice work!
                          • oasiscdm
                            • Jan 2012
                            • 1239
                            #118
                            Way to go Wayne. Awesome work, and I agree Hebel is soooooooo easy to use.
                            Cheers Colin
                            Oven 1 Completed
                            Oven 1 and surrounds
                            • Wayne73
                              • Oct 2012
                              • 133
                              #119
                              My first try at cooking in my oven...Pot roast and snags for the kids
                                • 2848
                                #120
                                Gudday
                                Congrats ....looks good ..... And works as well as it looks I suppose we all have that little bit of doubt so that first meal taste the better for it..
                                Regards Dave
