Wood fired oven corner build in Grafton NSW
  • Re: Wood fired oven corner build in Grafton NSW
    Ok so I redid the outer arch.. long story short I wanted a "heat break" inbetween the outer arch and the dome and it wasn't going to work the way I was building it.
    This also ment sacrificing the entry arch.
    My build. http://www.fornobravo.com/forum/f51/...ton-18665.html
      Sweet looking work. You will be very happy with that oven.
      Chip
      Chip
        Originally posted by mrchipster View Post
        I have a 42 inch oven with a 10 inch and it burns nicely. No smoke in my face and heats easily within 90 minutes to pizza temps.
        Chip
        Thanks for your imput Chip, Its about 2 meters from arch to the ceiling, do you know if length make any difference with the flue diameter?
          Finished !!! ...the brickwork anyway.
          I've added some decorative bricks to brake the front up a bit and I have them hanging an inch or so lower then the outer arch as I plan on adding a "smoke brake".
          I've got my insulation ready to go.
          Then the plan is to box it up with metal frame,blue board and then render.But I need to work out the flue first.
            Great job WayneO.
            Just a question as to your 'slab' under your brickwork. What's the measurement? Reason I ask is that I've poured a 100mm thick slab around part of my home and where I'm going to build the outdoor BBQ & WFO I negleted to 'add' extra measurement.
            So, where I have to build the slab will be 100mm, is this thick enough? I don't wish to 'cut' up a portion of slab to pour a thicker slab. My area is big enough for a 44" WFO, so that's what I'm going to build (hopefully).
              Yeah Its just a standard slab 100 mm all the way though no extra thickness or footings.
                Cheers.
                Not to hijack your thread as I don't have a build thread (yet).
                  No worries, If you not wanting to hijack you could always send a pm.
                    Progress ...
                    Hebel blocks make life easy.
                    Perlite for insulation Ive added five 100 ltr bags and i will need at lest two more.
                      You do very nice work, worthy of other to follow in the future.
                      Chip
                      Chip
                        thanks Chip.
                          A shame to hide your fine looking doom. Nice work!
                            Way to go Wayne. Awesome work, and I agree Hebel is soooooooo easy to use.
                            Cheers Colin
                              My first try at cooking in my oven...Pot roast and snags for the kids
                                Gudday
                                Congrats ....looks good ..... And works as well as it looks I suppose we all have that little bit of doubt so that first meal taste the better for it..
                                Regards Dave
