Wet Oven Floor
  • Liteceeper
    • Jul 2013
    • 90
    #31
    Re: Wet Oven Floor
    Originally posted by david s
    Some perlite gets treated with silicon which makes it non absorbant. This is probably what the manufacturer uses. I wish I had access to some.
    Hi David
    Exfoliators in Victoria do Premium Lite Fill which is a treated perlite comes in 100 litre bags.
    Lightweight Perlite Insulation & Hydroponics | Exfoliators
    Ben uses it in his kits.
    Liteceeper
    My Build - http://www.fornobravo.com/forum/f51/...ide-19729.html
    My Door - http://www.fornobravo.com/forum/9/sh...tml#post170496
    "Not everything that can be counted counts, and not everything that counts can be counted." - Albert Einstein
    • Liteceeper
      • Jul 2013
      • 90
      #32
      Re: Wet Oven Floor
      Better link
      Lightweight Filler & Render Insulation | Exfoliators
      Liteceeper
        Re: Wet Oven Floor
        Originally posted by Liteceeper
        Hi David
        Thanks Litekeeper,
        Unfortunately 2600 km would kill me on freight and my local manufacturer doesn't do the coated stuff unfortunately.
        • hungng
          • Jun 2011
          • 25
          #34
          Re: Wet Oven Floor
          I live in the tropics so driving rain is often a part of life especially in the wet season. I have never sealed my entry and landing with any sort of waterproofer. Someone mentioned sodium silicate. Does anyone know where I can get this? I assume its not Bondcrete.
          I'll be definitely drilling a few holes in the support slab too after reading that suggestion.
          My oven and entry are all clay brick btw.
            Re: Wet Oven Floor
            Sealing the entry won't achieve that much IMO. If there's water falling on it in that area that water has to go somewhere and between the gaps in the bricks would be my guess which means the bricks still get wet anyway. Waterproofing them also means that removing the water will be that much harder because you are preventing the water from coming out too.We live just south of you (Townsville) and the oven always gets really wet during the wet season. A few long slow fires does the trick to restore normal function though. I think the only real solution is a roof over the oven. When the humidity is really high I think the porous refractory gets wet just from absorbing it from the atmosphere even if if it hasn't been rained on.
