New 42'' pompeii build in Canberra
    • 2848
    #61
    Re: New 42'' pompeii build in Canberra
    Originally posted by Dan W
    Thanks for all of this. Must admit, the argument of lack of water absorbtion in blanket (vs vermicrete) for both curing, and if(/when) the oven gets wet is an attractive property that might mean I should go get more blanket and do away with vermicrete entirely. Given the only underfloor insulation Ive got is about 120mm of vermicrete, what thickness of blanket do you think would be sufficient to retain heat in the oven to cook for days - as that is something I definitely want to aim for.
    And thanks for the reminder about the vent in the render - had forgotten about that gold idea, which I agree is a very wise addition.
    G'day
    The standard is 50 mm ceramic or 100 mm V-Crete ". You have 120 mm on the bottom ." Plentiful sufficiency" I'd say. Aim for 50 mm blanket any more a bonus. The stuff I used a box of 25 mm gave me 50mm over the dome.
    You might find yourself spending a bit of your " beer pocket money" with the new job you'll have nothing to spend it on... Lucky bugger
      G'day Dan
      Congrats on the new job.... There would be a few out there that would consider it there dream occupation!
      My own thoughts on the insulation. 50 mm blanket is worth roughly the same insulation value as 100 mm of V- Crete, without the water. I've helped someone with a pearl-Crete insulation layer and its a shit to work with, cheap, which is good, but you have to let the stuff dry for ages. You have a dry dome so why not trust in the ceramic insulation you have if you want more insulation add more ceramic. You can render over ceramic insulation easier than trying the v-Crete then render.
      I have no thermal break it allowed me to support the rear of the chimney on the front of the dome, I don't find I have a great heat loss.
      A simple way to achieve a heat break is to place a spacer, say a couple of layers of 4 mm ply. Remove later and backfill with V-Crete later. On the floor I bed a length of angle aluminum or stainless in the V-Crete to give you a more durable surface.
      On curing your oven there's a section on firing your oven give that a read its tried and proven.
      Hope something here might help
      Great work , love the pics
      I prefer the thermal break to be between the flue gallery and the outer decorative arch. If the gap is made of a material like vermicrete it will also act as an expansion joint so that the whole inner oven, gallery included can expand and contract completely independently from the outer shell which includes the outer decorative arch. This way you can still have your flue gallery insulated and integrated into the dome for strength and support of the chimney.
      • brissie
        • Sep 2013
        • 127
        #63
        Still not entirely sure how I'll do thermal break - but will do one somehow. To achieve a "no catch" floor - which is currently immaculately flat and smooth, I Was thinking of laying a thinish (50mm wide) line of vermicrete across the inner arch entry to within about 20mm of the floor surface, and then notching a 50mm wide "trench" across the base of some floor bricks to within 20mm of the surface - but after reading comments here - sounds like that would be a good chance of cracking due to in/out temp diff and heat/cool cycle. Thoughts?
        Once again, thanks for all your thoughts/advice/views/opinions - love this forum!
        I did two thermal breaks
        It may give you some ideas. I put a 2 to 3 mm gap between both inner and outer breaks. I filled the inner one with ash, and the outer with sieved vermiculite/cement mix, at the upper part of the join.
        You can feel the heat difference between the 3 sections, if you put your hand on or near the brick and tile surfaces.
        Some photos...
          • 2848
          #64
          G'day Brissie
          Great pics noticed something that lit the lightbulb. You also have a tiled surface at the entrance, right. I know one oven that has tiles but no thermal break. Quess what ... Broken tiles ! They don't like the heat, and I recon its important if you are to use a tile surface that you do build in a thermal break to protect them from the heat.
          G'day Davids
          Like the oven in your avitar the thermal break behind the decorative entrance and in front of smoke chamber and chimney means the oven is pretty much totally insulated from the outside. That not really common for a igloo design but more achievable in a doghouse design. My entrance protrudes to much for that to work I recon. To late for mine. But now I understand and appreciate the design of your ovens
          • brissie
            • Sep 2013
            • 127
            #65
            G'day Brissie
            G'day Davids
            Thanks Dave,
            The heat isolation is good, with the two breaks. The front tiles only get warm and mostly from the radiant heat from the fire.
            I cooked pizza on Sunday, closed the door about 400c, next day Monday still had 230c cooked a roast, next day had over 100c and toasted muesli. thats 3 days above 100c.
            I think the heat breaks and good insulation are the reason. I think it pays in the long run if you plan to reduce heat loss.
            Steve.
              G'day Davids
              In my case because of the way I've designed the floor I was unable to put a heat brake/ expansion joint between the oven and flue gallery at floor level. Becsuse I made th flue gallery quite light (11 kg) there is little thermal mass in it to zct as a heat sink. Seems to work ok.
                • 2848
                #67
                G'day
                And if you don't have a heat break?
                Mine doesn't I didn't have the knowledge or the skills when building mine. I'd don't believe the entrance is a big heat sink robbing the heat from the oven, nor radiating the heat away like the fins on a motor bike engine.
                I think that an oven without a heartbreak has something else that comes into play. The entrance and flue is preheated by the radiant heat from the fire and the hot flue gases.
                Anyway I'm still able to get the oven to pizza temp in a goodly time frame (2 hrs) maintain that, close of the oven with an insulated door to bake at 200C to 250C next day, and still have 100C to 120C the day after that.
                That's not dissimilar to most other ovens that I'm aware.
                So its a good and sensible thing to have, lack off will not cripple an oven. It seems to always come back to one thing , lack of insulation is the main thing to stop an oven working efficiently.
                  G'day
                  Yes, I agree with you. I believe that the heat break as an expansion joint to reduce the tendency to forming cracks in the outer decorative arch or the igloo shell is a far more important reason, unless of course you like having cracks on the outside of your oven.
                  • oasiscdm
                    • Jan 2012
                    • 1239
                    #69
                    Hey guys I'm curious with your heat retention figures. after pizza I Chuck 3 more pieces of wood in. Let it burn for around 90 minutes. Remove the fire, now I haven't got a door but use some hebel and Calsil, in entrance.
                    Following day I get around 300 - 350c, from there it drops around 60c per day.
                    Cheers Colin
                    Oven 1 Completed
                    Oven 1 and surrounds
                    • ATK406
                      • Jul 2012
                      • 206
                      #70
                      That's pretty awesome heat retention in my book. I haven't built an insulated door yet (don't ask me what I'm waiting for), but I usually loose more than half my heat in the first 12 hr period (with the door closed) and half again over the next 24. That is dropping from around 450C to 200C in the first 12 hrs (that is still more than enough to cook with), and then again to about 100C by the next day.
                      I also have not finished my exterior yet (only a simple dog house covering the vermicrete render that I applied to my ceramic blanket). All told I only have 65mm of calsil under the floor (wish I had more but it was expensive) and about 90mm of insulation on the dome. I also do not have a heat break or insulation around my landing/vent. I hope to improve the heat retention with an insulated door and another inch or two of vermiculite on the dome but I don't think it will do much. Maybe I should put some vermicrete around the entry way too.
                      If you are only losing 60C per day I would say you must have one of the most well insulated ovens out there – Good Job.
                      Regards,
                      AT
                      • oasiscdm
                        • Jan 2012
                        • 1239
                        #71
                        I don't have an insulated door yet. As I need to learn to weld.
                        However I will monitor my temps. Tonight I fired oven. Closed sure temp around, 420c
                        Without an insulating door. Internal brick temp 460c external brick temp 380c
                        I expect in around 2 hours to have a temperature around 400c which will drop consistently around 60c each day.
                        Cheers Colin
                        Oven 1 Completed
                          • 2848
                          #72
                          G'day Colin
                          Sounds like you oven is working well that's a pretty impressive set of figures.
                          I used to believe you went hell fire with the temps and then cooked to the pattern of the oven as it cooled. In practical terms its frustrating and inconvenient to wait till things cool.
                          You only get out of an oven what you put into it.... So these days I tend not to put as much heat in. It's not about the wood its more about the convenience of being able to use the oven when you need to. It's easy to bring a cooling oven up to the temps you want than have to wait for a super saturated one to cool.
                          The main temps I'm interested in these days are the ones on the floor and that 150 mm above cause that's were the food is.
                          In saying that I still fluff it and get the temp wrong. That's why they invented trivets and aluminum foil for!
                            I agree with you Dave. It would be a drag to have to wait for a couple of days until the oven was cool enough to bake your bread. To save time and fuel I regularly fire my oven for only one hour exactly. At that point the dome has usually started to clear at the top and not much fuel has been used and not very many coals produced. If doing a roast I wait, with the door off, until the temperature has dropped to around 270 C. I then place the roast and door it, although the heat has not properly penetrated right through it is still plenty to cook a roast.The temperature drops off faster as the heat is still soaking deeper into the walls and floor, but that works pretty well for most roasting situations, start hot and finish cooler. Or if baking a few loaves of bread, I wait a little longer with the door off until the temperature drops to 220 C then place the bread and door it.
                            Using the oven this way allows roasting or baking after getting home from work.
                            • oasiscdm
                              • Jan 2012
                              • 1239
                              #74
                              Hi guys
                              I do have about 4 recipes I use when that temp is around the 350c mark. Kleftico being one which I am doing tonight in around a 320c oven for 4 hours. Beautiful dish as long as the pan is sealed very well and enough liquid is added.
                              But I also use the methods you describe from time to time as well.
                              Cheers Colin
                              Oven 1 Completed
                              • Lancer
                                • 423
                                #75
                                Wonderful, I can't wait until the weird deck ornament I built becomes something useful. I envy you guys the fun you are having cooking in your ovens.
