Materials supplier in Brisbane
  • Materials supplier in Brisbane
    Hi everyone. Very early days for me, still gathering info. Have collected enough besser bricks for my base, cleared a spot in the yard, boxed it all up and I'm ready to pour the first foundation slab. I have also gathered about 100 SRIC K43 furnace bricks. They all need to be halved as they are large and I believe they are 43% alumina. 2 questions, 1. Will these bricks be ok for my dome? and 2, Can anyone put me onto a supplier in Brisbane for insulation material, Floor bricks, Cement fondu? Mortar, flu, door etc... Thanks in advance.
    Re: Materials supplier in Brisbane
    Firebricks and fireclay - Claypave
    Cement Fondu - Lyndons
    Flue - Mr Stoves
    Insulation floors and walls - Thermal Ceramics, Total Refractory management
    Hope that helps
    Brett
      Thanks Brett, going shopping soon.
        Flue - Mr Stoves
        Hope that helps
        Brett
        Fireclay from Claypave is a true fireclay designed for high temp refractory use.It is not cheap. I believe that the temperatures we fire to do not warrant such a product and as a cheaper and more readily available clay, I use Bricklayers clay.I also find the Claypave fireclay a bit gritty and coarse and not so suitable for mortar.
          Hi Brett Got my supplies in Brisbane from the following
          Bricks and fire clay - Claypave Ipswich
          Flue - online from Pivitonline - Melbourne
          Vermiculte & Perlite - Capalaba produce
          CF board & blanket - Total refractory management -
          Hope that helps
          Cheers
            Thanks everyone. Got it all now. Total Refractory Management for the blanket, Capalaba produce for clay, cement, sand, lime, will make poor mans mortar as everyone swears its good as gold. Flue from BBQ's Galore at Capalaba of all places. Already had my bricks using them as the floor also. Bought some fancy bricks from Rochedale brick works to use on the outside of my arches as the fire bricks are a bit bland. All set...
              Gudday
              Oasis hydroponics in Caplaba for pearlite vermiculite has a lot of different grades of both.
