Making my own tools
  • nissanneill
    • Apr 2007
    • 1886
    #31
    Re: Making my own tools
    I find stainless steel quite easy to drill, but you must use sharp drills, keep the speed down and keep pressure on the drill to cut. If it fails to cut and keep cutting, then it will burn the bit.
    I was in a line at Bunnings tool centre buying better quality small replacement drill bits (as you and especially your son breaks them more) when the guy ahead of me had a pack of unbranded Made in China drill bits that he was only doing a price check, $1.79 per pack!
    I made a comment on cheap drills and he claimed that they weren't bad, so I bought 2 sets, bought them home and using a 4mm bit drilled 34 holes using a drill press through a 1.6mm 16 guage stainless sheet without any burning of the drill. I then went back to Bunnings and bought every set at both their Marion and Mile End stores. Even though they were unbranded, they were as good as any Frosts, P&N or other quality brand that I have experienced.
    Neill
    Neill’s Pompeiii #1
    Neill’s kitchen underway
    • Chaz Aus
      • Jun 2012
      • 47
      #32
      David, Neill
      Drilled the few holes I needed this morning and followed both your tips and was definitely easier. I was obviously drilling to fast and burning the ends of the drill bits.
      Here are a couple of pics with the finished tools. I also decided to build an aluminium holder for the containers I use to hold all the toppings. I will include some pics of these on another post.
      Thanks for your help
      • Chaz Aus
        • Jun 2012
        • 47
        #33
        My tray holder I made this morning
        • Chaz Aus
          • Jun 2012
          • 47
          #34
          And with trays in it!
            If you put some sides on the holder, you can fill it with ice to keep the stuff cold.
            • Chaz Aus
              • Jun 2012
              • 47
              #36
              Added another tool! This one is for moving dishes/trays around.
              I used a reasonably heavy duty tent peg I had in the shed, drilled a suitably sized hole and glued. Hopefully the glue won't be an issue but guessed that i won't have it in too long anyway. If not I'll go to plan B (not sure what that is yet!)
              Cheers.
                Originally posted by Chaz Aus
                Cheers Dave
                Lets say that some of the money I saved making my own tools has been spent on a few drill bits! Didn't realise how hard it is to drill s/s even with the proper drill bit.
                Still have a couple more to drill but have gone too far to now go to an eng. firm.
                What do you thin the varnish with?
                When drilling SS, if the bit squeals then you've blunted it.
                • CrocAu
                  • Apr 2013
                  • 164
                  #38
                  got couple quick ones for you, is this shovel handle from bunnings that you use there and how did you cut the grove for the tool heads to go in the handles? if SS is 1.5mm i'm worried my saw will cut 2-3mm and make the handle weak
                  btw did you get the off cuts for free or you paid for them? i almost got some today but they wanted some money for it.
                  i know recycling centre got some SS at $50 for whole brand new sheet so I might just go with that
                  • Laurentius
                    • Nov 2010
                    • 923
                    #39
                    Hi CrocAu,
                    You might want to re-read the above and edit.
                    • Chaz Aus
                      • Jun 2012
                      • 47
                      #40
                      Hi Croc
                      Yes the handles are from bunnings. I just used a jigsaw to cut the grooves. Was going to use a circular saw but decided against it. I think a hand saw would do the job also.
                      If you can get the S/S sheet for $50 get it. In Adelaide a new sheet of 1.5mm was around $300. I had to pay for the offcuts. They charge by weight.
                      No problems with the strength of the handles. The cut width using the jigsaw allowed a firm fit. Bolting the heads gave it some strength back. Time will tell.
                      I used the rake and brush yesterday to clean out the WFO from my last pizza night and both worked well. The rake worked a treat and I was able to get all around the oven with the brush.
                      • CrocAu
                        • Apr 2013
                        • 164
                        #41
                        Originally posted by Laurentius
                        Hi CrocAu,
                        omg, nice find
                        • CrocAu
                          • Apr 2013
                          • 164
                          #42
                          got some really nice off cuts today, more than i need so will have a blast with that
                          • Chaz Aus
                            • Jun 2012
                            • 47
                            #43
                            Great news. You will definitely get satisfaction out of making your own tools. Used mine on the weekend for the first time and they worked well.
                            Did you end up having to pay for the offcuts?
                            Please post some pics of your tools when done.
                            Cheers
                            Chaz.
                            • CrocAu
                              • Apr 2013
                              • 164
                              #44
                              yes i did pay a little, got few for free as well, i'm sure i will find use for it
                              • Dazmac
                                • Jul 2013
                                • 11
                                #45
                                Hello Chaz,
                                are you able to send me the plans/templates for your tools as they look great
