Mudgee build
  • Mudgee build
    Hi guys, new build using one of Ben's kits from Melbourne firebrick company.
    plan on having the opening flush with the base, will form up the top slab section once the oven is built.
    Plan to render it tomorrow
    Re: Mudgee build
    G'day
    Welcome
    Like that stand. Like the shape it will give you some space on the sides which is a good thing
    Also like the idea of the hearth and slab height being the same, that should look good.
    Keep the pics coming
      Re: Mudgee build
      Nice promising build
      I forgot who said that.
        Re: Mudgee build
        Hey Bowser - Looks like you are off to a great start. My only question is do you have access to under the slab to use all of that space? Look forward to following your build.
        Cheers ......... Steve
          Re: Mudgee build
          thanks guys, no access under the slab, plan on extending it either side for BBQ and outdoor kitchen so won't really be able too.
          1st coat of render also went on the weekend, still has the formwork under to opening which is now removed.
            Re: Mudgee build
            Rear and/or side access would have allowed that but guess it is too late for that.
            Cheers Colin
            Oven 1 Completed
            Oven 1 and surrounds
