Hi,
I've planned and built the base for a wood fired earth oven using knowledge I've gained from this website.
Now I'm ready to build an Earth oven and am looking for a suitable supplier of clay in Melbourne, preferably the Western Suburbs.
The base has a 10cm vermiculite thermal layer above a 10cm reinforced concrete structural layer. Then it is capped with 8 fireclay tiles.
Inside diameter is a bit on the small side (600mm-700mm depending on how thick I make the dome).
I made a small test dome using clay from my small backyard, but won't have enough to make a full oven including the insulating layer.
Can anyone recommend a suitable clay supplier in Melbourne?
TIA.
TIA.
