It's manufactured by CSR give them a call. Try chasing Hebel Power Panel, they have steel reinforcing embedded in the middle. There is also a special Hebel glue availsle to stick them together.
Reason: spelling again
Try chasing Hebel Pwer Panel, they have steel reinforcing embedded in the middle.
Yup that's the one I'm chasing. Trying to get a bit of strength in them. Hebel is so brittle. I was scratching them with my fingernails at bunnings and most of the hebel bricks were cracked through the middle.
I wondered how they are even used for buildings. They break so easy. Kinda worries me it would crack under the oven.
But I've managed to find a few suppliers close by.
G'day Charlie
Great to see your oven.... turned out quite handsome.... Well done.
What did you finally use under the oven? Were you able to get the hebel power panel in the end?
I wouldn't worry too much about the render layer sounding a bit hollow. My oven was rendered for years and the only crack was where the chimney meet dome. I bricked the dome over and you guessed it, cracked again. Diference in expansion due to heat.
I was always a bit worried about kids climbing over it but they didn't cause any damage and I finally brick veneered over it for aesthetic reasons mainly. I really like the look of a "brick oven. If you worried give it a further coat of two of render.
Again a job well done
Thanks cobblerdave.
Managed to find all the materials i needed and they were close to home.
I got a strong 10mm compressed cement sheet on the metal stand. 75mm hebel ontop and then the oven. How it will all play out remains to be seen. I had enough thinking and just wanted to get the project started.
Despite the weight, the oven is easy to move around on those wheels.
Before painting and adding the nice outside design, I'm going to start curing the oven in the next few days slowly to see how it will stand up to the heat. If it cracks I'm thinking of sealing the cracks with high temp mortar that came with the oven. If its bad I might add another render layer.
Actually I might not do any outside design and paint work until the oven has been used for a couple of months. I'll see how I go.
Only thing left now is the flue kit and I need to find myself a nice stone to place under the arch opening to make it level with the existing oven floor.
It's looking good. Can smell those pizzas already. I was going to ask how difficult it was to move around but you've already answered that.
I like the arch as well. Probably because it looks a lot the one that I just made and I was worried about the structural integrity as it was rather 'flat'. But if yours is OK, then it gives me more confidence that mine will be as well.
Well after 5 years of thinking, deciding, researching, debating, reading, arguing, forgetting, comparing and all the "ings", we finally lit the first curing fire of our oven on Sunday.
It was like "man discovering fire" moment. I had no idea what I was doing or how big "big" is supposed to be for the first firing but we did it.
One of my main fears was how much smoke was going to be let off but thankfully it was barely visible or noticeable.
Like steady also got barely noticeable hairline cracks at the opening. Hoping it stays that way.
The kindling I got from bunnings worked well. The hardwood was rubbish. The log didn't light up and just sat there turning into charcoal. Need to find better wood somewhere.
Good to see PizzaCharlie, it's a good feeling to finally turn some refactoy products into a WFO after going through all of the "ings" -
I feel for you having to buy wood from bunnys, I have my own bush to source fuel but the sticks I used on the weekend were fairly smokey. I will need to gather some good 'stuff' To use for cooking.
