Found easy way how to hold bricks in place without any problems and use of IT only for reference for first brick to get exact angle .
New WFO in Perth
A variation of this concept shows up periodically. Just goes to show there is more than one way to skin the cat.Comment
Like I said, more than one way to accomplish the end goal.Comment
Hi Yandi,
It looks like you're starting the curing fires on an oven that has no dome insulation. Whilst many builders have done it this way without problems, just remember that an uninsulated clay chimney is bound to crack because of the temperature difference between the inner and outer surfaces. The same applies for an uninsulated dome, so for this reason it is better to insulate before fires IMO.Kindled with zeal and fired with passion.Comment
