After many years of investigation and planning, I finally decided last year to build a Polito oven - a Donatello in particular.
The guys at Polito were great. Very knowledgeable and very helpful.
I decided to build the myself which allows me to save some money, have the fun of building it, and also do it my own way. I want my oven to perform a bit different from the factory built ovens in that I am hoping mine will get to temperature faster (400 degrees is about 1 - 1.5 hours, or faster) which means it won't be as hot the next day. I don't expect I need the heat retention after 12 hours - if I do, I'll put a log in.
Anyway, I picked up the kit before Christmas and built the firmware for my base and welded up the stand (see pics).
I also poured the slab for the base on Saturday. I used 15 bags of premix high strength concrete (55 mpa) from Bunnings.
Once it dries properly, I start on the oven.
