I’ve been planning out my build essentially following the Forno Bravo “Pompeii Oven Plans” as closely as possible.
Unfortunately the cost of everything in the UK seems to be astronomical compared to what the guide suggests…… I wonder if I’m missing something major in my planning and buying the wrong stuff? The price of concrete seems to be killing my project completely.
Any help would be greatly appreciated, and advice on where to buy stuff at the cheapest possible would be amazing!
Foundation:
Fortunately I already have a concrete slab as a foundation.
Base:
As per the guide, I’m planning to stack up hollow concrete blocks to make my base and pour concrete down alternate cores.
Hollow concrete block construction. 70x blocks @ £2.40 = £168
Concrete 25kg readymix bags 15x bags @ £9.36 = £150
The concrete seems outrageously expensive- I thought concrete was supposed to be cheap?
Cooking Surface:
A 9cm thick, steel reinforced, concrete slab with a further 9cm thick vermiculite concrete on top.
Sand/cement to lay down underneath firebrick cooking floor.
Concrete block 1.2m x 1.2m x 0.2m. 25kg readymix bags 30x bags @ £9.36 = £300
Vermiculite for insulation in concrete top layer. 100litres= £18
Firebricks x60 @ £1.60 = £96
Rebar for concrete ½” x 9m = £51
Sand 50kg = £5
Portland Cement 50kg = £10
Again the concrete is killing me here….£300!
Dome:
Firebricks x 120 @ £1.60 = £192
Procast 1400 castable (25kg bags) x4 @ £18 = £72
Chimney:
£30 steel stove chimney, with covered top, from eBay.
Insulation:
Ceramic fibre "s" blanket 38mm 128kg x1 = £60.00
Vermiculite 100lites = £18 (don’t know if this is enough?!)
Rendering…. Not priced up yet but dreading it based on the above.
External plaster/render
Wire mesh + rebar
So far the price of the above is £1088 which is significantly more than I was hoping.
Does the above outline sound like everything I need, and what are your thoughts on the prices (especially the concrete?).
Any help would be hugely appreciated,
Jon
Foundation:
Base:
Cooking Surface:
Sand 50kg = £5
Dome:
Chimney:
Insulation:
Wire mesh + rebar
Jon
.) My initial loaf of bread was pretty spendy when I added the overhead...but after 3,243 loaves I'm at $0.57 per average loaf ingredients and $3.33 overhead for each loaf (total cost per amortized loaf = $ 3.90)...and my neighbors are now all really good (and hungry) friends!
