Starting the fire help and brush?
  • czaunb2
    • May 2010
    • 53
    Do you have any tips to share for getting the fire going? It seems to be taking me a REALLY long time (nearly an Hour) and a lot of TLC to get the fire really going which is hard to do with 2 young kids. I am using twigs and cardboard to light oak pieces currently. I did just get a new batch of firewood so maybe that is the problem; but, the guy did tell me that it is dried properly (and I have used him before without problems). I figured that this can't be normal as you wouldn't be using the oven that often if this were the case. Any suggestions?
    Also, I know that I need to order the FB brush, but until then is there anything that you would recommend that I use? Would a grill brush work for now?
    I was trying to delay the upfront costs by only getting tools that I absolutely need and have purchased the peel, themometer and gloves. They are GREAT, but I need a way to clean the space where I lay the pizza. Do I have to spring for the brush now, or can it wait?
    As always, thanks so much for the help!!
    Claire
  • Tscarborough
    • Oct 2009
    • 3341
    Re: Starting the fire help and brush?
    I do 1 match starts. 2 logs on the sides about wrist up to 6" with loose wadded newspaper in between. Then across that a layer of 3/8" or less x 6" long twigs, then 2 or 3 wrist or smaller parallel with the first ones. I build it in the entry, then push it in, and light it. Even with damp wood it still fires off.
    I do not put a whole lot of wood to start, once it is going I feed it.
    • czaunb2
      • May 2010
      • 53
      One match starts--that sounds nice. This plan does sound better than what I have been doing--more like one lighter starts :-)
      Thanks so much!!! I think I will go fire it up now.
      C
      • Grimaldi
        • Dec 2008
        • 106
        Another thing that gets things moving faster is a propane torch on start-up. Build your fire with tender, kindling, and graduating larger pieces...tipi style is how I do it, then light it with the torch for a few minutes - you'll have a blaze going in no time.
        • Neil2
          • Oct 2006
          • 1374
          "Would a grill brush work for now?"
          No. They have steel wire bristles and will degrade the surface of your fire brick. You want a copper or brass brush.
            • 9208
            If your oven is new it will still be moist and a bitch to fire. Just keep firing and it should get better. On the subject of a brush I always use a length of 12mm copper pipe to blow the ash away from the cooking surface rather than a brush. It works really well and is also useful for starting stubborn fires.
            Dave
            • fxpose
              • Jul 2009
              • 942
              Thanks for that idea. I will use a length of copper piping for now and see how that works out.
              George
              George
              My 34" WFO build
              • Tscarborough
                • Oct 2009
                • 3341
                Here, I found a pic of the firewood just before I push it in:
                • kebwi
                  • Aug 2009
                  • 1090
                  Yep, 1-match starts for me too (I was a boy scout so I get VERY frustrated if I lose it on the first match. ). My approach is similar to Tscar's except that I make a much bigger mess before I light it; it never looks as pretty as his. Same idea though: large logs on the bottom to build a "house" for the tinder and kindling, then I stuff wood in there until the outside of the oven starts bowing out (j/k). Then I light it and stand waaaay back. It's fun watching it explode into flame.
                  If you're having trouble, determine which stage you're losing it at. If it's immediate, your tinder is too wet. If that burns out without catching any wood, your kindling is too wet (or too big). This advice makes sense of course.
                  Best of luck.
                    • 9208
                    Half the fun of these ovens is the playing with fire. That primevel thing, me Tarzan you Jane stuff. Hmm makes me feel like grabbing my wife by the hair and dragging her to the... sorry getting carried away.
                    • altamont
                      • 43
                      Forget paper. As a Boy Scout I stumbled on using wax paper! Heck of a difference and if it gets wet it dries fast. The wax helps generate higher temperatures. Just crumple up pieces of wax paper (I use it instead of plastic wrap whenever I can in the kitchen) like you normally would with paper.
                      Top Down fires only for me after learning about them here and trying them.
                      • Vickie
                        • Aug 2008
                        • 21
                        Especially for getting started... I would kind of skip the copper pipe. Do a search on bellows, I posted some plans to build some a while back.
                        I used an old shelf for the wood and some leather out of the scrap bin at a fabric store -- any thick upholstery fabric would work too.
                        Much safer than accidentally taking a breath with the pipe in the oven. And the bellows will blow the ash clear too.
                        About the brush, I have rather stringent budget concerns myself.... I use a wooden handled wall paper brush screwed to a long stick. Dip it in water or mist the bristles and sweep...
                        • fornax hominus
                          • May 2009
                          • 157
                          Re oak firewood
                          I burn a lot of firewood keeping 3 buildings heated through 6 months of snow cover and of all the types of wood I burn oak can be the most tricky , The local red oak has to be aged 2 years before most of the locals will touch it . if it hissed or foam /wettness shows up on the end it's wet! Try putting the next firings wood in the oven when you have finished cooking and leave it in with the door open to ''force dry''
                          tim
                          • FrankF
                            • Jul 2009
                            • 11
                            I cheat I use charcoal starter packs. I build the logs up like Tscar but instad of newspaper I put the starter pack on a thin piece of wood and light the pack on fire. Fastest way I have fould to get a good fire going. You can find them at home depot or I have a recipe somewhere on making them yourself.
                              • 9208
                              Someone on a previous thread suggested used and dried teabags with the strings removed, placed in a jar of methylated spirits. I now do the same. I used to compost them but they don't break down for some reason and the strings are a nuisance.
