My oven has a short chinmney with a damper. This damper moves 90 degrees from open to closed positions.
What I'm wondering is when do you use the damper? Should I dampen back the chimney when firing the unit to hold in some heat or is it better to let the fire go.
When cooking with a fire inside, again should the damper be used? Or should I just control the fire with the fresh air damper in the door? Seems like if the fire is burning well and I can dampen back the chimney it will hold more heat and consume less fuel.
And I'm assuming that if I pull out the fire/coals, it will be best to seal up all dampers to keep the heat in.
Thanks for any thoughts based on your experiences.
