Yesterday we tried our first attempt at making bread the 'NO Knead way'
The result wasn't brilliant but was OK, I think the problem was loss of heat in the dutch oven (a large pot with lid). I think by the time we inserted our dough into the pot it had cooled too much, the end result was a tight formation of the dough and still a little tacky within.
we also did another 3 loaves at the same time just on the hearth floor, these were actually a little better, not burnt but again still a little tacky within but not the crust I had hoped for.
This morning I reheated the oven until the oven began to go white and as I write we now have a pot roast (chuck beef) in the oven.
The reason I reheated the oven so I could sear the beef chuck prior to the long intended slow cook..............this has brought it own little dilemma...
The temperature in the bricks now is average of 450 F (double the temp recommended for a slow pot roast as per the temp sheet posted by James)
This has me worried somewhat that the pot roast will be done too quick, however I have just tested the external temp of the cook pot and it is 230 F (which is within the recommended range for slow cook).
So still at the learning stages of cooking, I am looking for opinions as to my assumption that although the dome temps are high the pot being cooked IS actually at the right temperature?
Will this continue to draw the convected heat from the dome bricks and remain constant?
or will it become hotter?
Or will it become cooler?
I know I can go out and recheck at any given point, but for future reference for any type of cooking, I originally thought that what ever the temps of the bricks would be that is the temperature of the oven, maybe this is not the case.
I also learned today maybe that in order to sear the meat I should have lit a small fire, spread the embers and over a Tuscan grill seared the meat both sides rather than in the cook pot itself.
How do others sear a meat at high temps then slow cook?
Any thoughts suggestions are much appreciated. Thank you.
Paul
Paul
