What's your experience with converting recipes to WFO versions?...
The oven generally has a fixed temperature and it's just an oven, so don't overcomplicate the situation. I've found that most of the time it works out okay...common sense rules.
...and I'd generally opt for a lower temperature for a longer time vs the opposite
Things to think about:
where in the oven to put the item
do you want a smoky environment to add flavor
should the dish used go in cold or preheated
do you want to raise it off the hearth
whether you want direct heat from the fire or will need to shield it
should you cover it (particularly if you don't want the smoke)
when to cover it
whether to add additonal liquid, particularly for uncovered
moving the dish around the hearth to get different temperatures (hotter or colder) as well as turning it like a pizza
with lots of items you can also stack them ...terraced cooking!
food for thought!
when to cover it
food for thought!
