Re: Mixers
Yeast is like most everything else, it has a range of temperatures where it's comfy. Too hot or too cold and the bread won't rise properly.
I've never used a mixer, but I suspect that if it is starting to get hot from mixing you are over mixing, the equivalent of over kneading. You'll end up with something tough and chewy.
I don't like that kind of advertising either.
Originally posted by jmhepworth
View Post
I watched the video and wouldn't recommend buying the Bosch based on that alone. It was so biased in approach that the Bosch people should be embarassed. Comparing the slowest KA speed (a slow crawl) to the slowest Bosch speed (a pretty good sprint) is ridiculously misleading. If I recall right, KA recommends mixing bread at level 4, which is a lot more comparable to the Bosch speed. And my wife tells me that one of the down sides to the Bosch is that there is no slow speed.
I would still get the Bosch for bread, but it makes me pause when a company uses such obviously misleading advertising to sell its product.
Joe
Joe
