Re: Pancetta
This thread got me excited about making pancetta. I ordered pork belly from Sea Breeze Farms and I asked the guy about pink salt. He said that when he makes his pancetta, he only uses sea salt. I've found it fairly difficult to find an online recipe that doesn't include pink salt. The few I've found just said something vague like "I added more salt to compensate for not using pink salt." Not very helpful. I guess I'm stuck using pink salt, huh?
Re: Pancetta
I do whichever recipe as normal up through the wash and iar-dry in refrigerator. Then brush with liquid smoke when putting into oven on rack. Often I brush again when halfway to 150 deg. I never really measured but think about 1 Tbsp for a 5 lb bacon. Wrights is the best brand.
Re: Pancetta
I've heard about the liquid smoke, but never tried it. Need to do so sometime. Do you dry the bacon some before the "smoking" and how much do you use?
Re: Pancetta
Although real smoke is best, I sometimes shortcut: liquid smoke and oven roast in 200 deg oven, on a rack, to 150 deg internal temp.Originally posted by Pdiff View PostSmokers can be dedicated units (Big, Little, and Mini Chief products are excellent), or as simple as an electric burner and some flower pots (see Alton Brown on that one).
That's a very interesting site. Other recipe sources are Michael Ruhlman's Charcauterie book and the sausage book from Sausagemaker in Buffalo.
Re: Pancetta
Rossco, I wouldn't worry about the safety issue, just find a reliable recipe and follow the directions. Many people make American style smoked bacon without the pink salt preservative as they are cured in highly salted environments and are usually then "cooked" a bit while smoking and immediately frozen or refrigerated. The results, however, without the pink salt will turn grayish during cooking, which many of us aren't used to seeing in cooked bacon
. Pink salt, BTW, is regular salt with a small percentage of sodium nitrate (5-6%) added. It is dyed pink to distinguish it from regular salt. It is easily available online or locally if you have a good butcher or game processor around. You'll typically use a small amount per recipe.
In the case of the pancetta, I decided that, since it is not cooked, and it stays in an unrefrigerated environment for such a long time, I'd go ahead with the P Salt. The recipe I posted suggests drying at 60*F, and some have reported going as high as 70*F, but that seemed like it was just asking for trouble. The temps outside here were running 30 - 40*F (very mild winter!) so I put it under cover of the grill. A frig would work as long as you kept it well aerated with good circulation. Some people go as far as using one of those small refrigerated wine cabinets the big box stores often carry. For me, the grill solution worked and was safe and sound. Well, mostly ... I did have a few sleepless nights after my niece crossed paths with a bobcat in our barn and I kept imagining it trying to get into the grill, but that's, as they say, another story
Think about starting with some smoked bacon. It's an easy process and your family will never look at you the same after you throw an 11 lb slab of pork belly on the counter
. The basic recipe I use came from here . Smokers can be dedicated units (Big, Little, and Mini Chief products are excellent), or as simple as an electric burner and some flower pots (see Alton Brown on that one).
Pork: It's great stuff!!
PdiffLast edited by Pdiff; 01-30-2010, 02:05 PM.
Re: Pancetta
I can't speak authoritatively to the safety implications (I've made plenty of bacon, including pancetta, both with and without pink salt)... but without curing salt the bacon never tastes or looks quite right.Last edited by BrianShaw; 01-30-2010, 12:27 PM.
Re: Pancetta
This sounds rather complicated now. What sort of safety risks are involved? Do you risk getting food poisoning ... or worse?
Rossco
Re: Pancetta
My understanding is that is really crucial for safety when curing meats. I have been wanting to try to cure some pancetta myself. I made some bacon last year that was really good...
Re: Pancetta
Yes, sorry. I didn't mention that, as Rossco was asking about seasoning, but it is important! I used the recommended amount of pink salt that I picked up at my butchers ... I was not comfortable with having the meat "hang" around for a couple of weeks without it.Originally posted by DrakeRemoray View PostYour ingredients do not list a nitrite cure (Prague Powder, instacure, etc). Did you use one at all?
PdiffLast edited by Pdiff; 01-29-2010, 02:24 PM.
Re: Pancetta
Re: Pancetta
The fridge cure part is similar to American bacon. I liberally apply the cure mix, stuff it in a large zip lock bag and lay it flat on a sheet pan in the fridge. It gets flipped every day and will start to weep, collecting liquid in the bag. After a week, it is removed, rinsed well, rolled as tightly as possible and tied and hung to air dry for two weeks. My house was too warm, so I dried in my gas barby outside. It doesn't pick up flavors (if anything, it imparts them on other fridge items :-) .Originally posted by heliman View PostSo there is no cooking/smoking involved?? Do you just put it in the fridge along with spices etc and that cures it?
I have made quite a bit of biltong/jerky in the past and apart from the spicing, that requires drying which has a preserving effect, but haven't heard of just leaving stuff in the fridge to achieve this. Does it not absorb other flavours from the fridge (like uncovered water does for example)?
Rossco
American bacon is smoked, which I do as well, and obviously not rolled. The pancetta is just dried and may be rolled or not.
Pdiff
Re: Pancetta
Rossco
Re: Pancetta
Those pictures look really, really good! There is not much better than fresh Pancetta!!!
Re: Pancetta
The recipe came from here, but my searching around the ether found that these are pretty standard ingredients: Salt, of course, garlic, brown sugar, pepper, juniper, bay leaf, thyme, rosemary and nutmeg. A one week refrigerated cure with these and then a two week hanging dry out. I probably over did the tying. For some perverse reason, I seem to enjoy tying roasts etc. The dogs always keep a wary eye on me when I get the string out ... :-)
