I started a new thread to answer your question about my rye fiasco. I did not want to hijack Bills thread.
Well this is my sad story. You know I keep three starters white, rye and w/w.
I planed to bake a bunch using my white starter that uses little starter % per pound. I wanted a few W/W but I wanted to work on my rye's again. (searching for that "One") and doing it right.
So I started to build the white and the rye and delayed starting the W/W because I did not need that much starter. Now my W/W starter is thick and looks like a wet dough, the rye is like tooth paste. Well I went to use my W/W and it was like tooth paste. It was not normal at all. The smell was off, the texture was off so I started to think I switched the marked lids between the rye and W/W. I inspected what I thought was the Rye and the smell and texture was also off. I could not tell the difference between the two. After fermenting the color, smell, texture got almost identical. I even tried to take a small amount of starter and wash it out hoping I could tell the difference in the sediment between the two.
So how could I screw up that bad. Started to think I built up my rye with W/W or built my W/W with rye...To this moment I don't know if I even made a mistake. Now I'm standing there with my starters not knowing for sure what is what.
I always keep a backup set of starters so I feed them and now have a for sure rye and W/W mother starter again.
So I took what I thought was the rye build and proceeded with the rye bread. 66% rye. I don't know if I fed this once with W/W or not. I adjusted the dough with more white flour and instead of slashing I docked.
The loaf I got was great in flavor and texture. Had great strength so it was nice and round and did not slack at all. Like I said it was one of my best rye's yet. But I don't know if I can reproduce it.
If I did not make a mistake in my feeding of my rye starter I can reproduce it. If it has W/W in the mix I will need to work on that.
Next bake I'll try again using all Rye. I'll keep a loaf in the freezer to make a comparison.
Sucks getting old and having senior moments.
So that's the story
So that's the story
