focaccia ?
  • dsm
    • Nov 2009
    • 96
    focaccia ?
    Hello, havent posted anything in a while just trying to finish the exterior of my oven. And of coarse experiment with different pizza recipes. I am going to try to make focaccia bread any good recipes out there would be appreciated also what temperature should my oven be for cooking focaccia and how long..?
    Thanks,
    Dave..
    Picasa photo library:
    https://picasaweb.google.com/1043493...lleryMay192012
  • dsm
    • Nov 2009
    • 96
    Re: focaccia ?
    Not all at once now,,lol..i would really like some input please on some ways of going about this process on making focaccia in a brick oven.
    • brickie in oz
      • 3445
      Re: focaccia ?
      Its just a thick pizza, ive done them at bread and pizza temps.
      • SableSprings
        Moderator
        • May 2009
        • 1310
        Re: focaccia ?
        Although there are several variations on formulas for the focaccia, Brickie hit a pretty good note on the subject. It's really just a thick pizza. I often take my leftover pizza dough and put it back into the refrigerator until my oven has dropped into the 500-525F range. I gather up my balls of dough (about 30-35 oz for a half sheet pan of focaccia) out of the refrig, combine them and let them warm as with pizza. Once the dough has warmed a bit, I stretch, press, and pull it out into the half sheet pan. Let it rise for an hour or two then give it the finger presses, dose it with herbs, EVOO, kosher salt, & pepper. I put the sheet pan in the oven at about 500F and plan on a bake of 15-20 minutes. I watch it closely and turn the pan around after about 10 minutes. Once you get a good brown on top, it's done...bring it out & let it cool a bit before cutting & serving (I use a pizza cutter on it.)
        Hope that helps a bit.
        Roseburg, Oregon
        • dsm
          • Nov 2009
          • 96
          Re: focaccia ?
          Ok thanks sounds fairly easy I am going to give it try this weekend..
          Dave
          • TropicalCoasting
            • Dec 2011
            • 408
            Re: focaccia ?
            I would have it as a wetter dough than a pizza
            Let it rise and a poke your fingers into it to give it the right look
            Focaccia from Genoa ( focaccia alla genovese ) recipe - YouTube
            I used to go to a pizza shop in Melbourne that basically cooked 2 very thin pizzas together and had garlic oil and a little parmessan/mozzarella in between it was excellent and they called it a focaccia .
            The ones I had in Genoa was very similar to that too but the pastry was almost a flaky pastry and there was 4 cheeses in it (it was excellent)
            • dsm
              • Nov 2009
              • 96
              Re: focaccia ?
              very good video thanks tropicalcoasting.
