So I decided this year to do a big bake for the annual Christmas sourdough for the neighbors present (a tradition). My usual MO is to just bake all day using the electric oven. However after reading Faith's, TexasSourdough's, SCChris' and others postings, I felt ready for the plunge.
I forget who's scaled up recipe I used (though I will find and give appropriate credit.) One modification I did was upped the water from 62% to 65%. I used the Chad Roberts method of Stretch-n-Fold with delayed salt addition. Way easier that is for sure.
20 boule's later... I liked the fact that I am nearing the home stretch. All of the dough is rising all over the kitchen island, table... Since it is so dry, I put plastic wrap on the tops to retain the moisture (standard practice from past bakes after the skin has dried a touch). I always remove the plastic about 10 minutes before the bake to dry it up a touch and avoid sticking.
I just finished - 17 loaves in the Pompeii. Found a hot spot in the oven (as evidenced by a slight trickle of smoke from my chimney caught just by chance!) and had to rotate the bread half way through - burned 5 bottoms. More problematic was at 40 minutes, the loaves were still blonde on top. I used the broiler to tan them up a bit. I am attaching pictures for review and comment from those in the know who may be able to troubleshoot.
Air temp in the oven was about 480 when the loaves went in. The crust does not look like it gelatinized at all. I have a loaf that I cooked in the oven using steam (dual slit, oblong on the left of the burned bottom) came out beautiful. The crumb is open and airy as can be somewhat seen.
Any clues? I am guessing my dome may not have been hot enough? Would using baking parchment be a viable alternative? What about steam via pan... Lots of questions.
Thanks in advance!
Thanks in advance!
