Here are pictures of my first sourdough attempt. Taste was GREAT, wish the crust was crustier. I got my starter from wholefoods. An extremely gracious baker just went in back and gave me some sourdough starter to try when I was inquiring about whether they sold cake yeast (which they don't). So I cooked the loaves at about 530 F and pulled them when it looked like they do in the pictures. Internal temp was 208 F. I put a very small tinfoil pan with water in the oven for the entire cook. Thoughts?
My first sourdough attempt
Re: My first sourdough attempt
I do the same thing except i use hot water, it works great.Originally posted by TropicalCoasting View PostLooks very good
For steam I use an old pan full of pumice that I let heat up and add cold water to it as I put the loaves in.
I get crusty loaves.Chip
Looks a hell of a lot better than my first attempt.
Thoughts...
You got the starter from a bakery so you know you have a highly active, completely mature starter. It shows. Good oven spring.
I think you are somewhat over-proofed. As a result, you have a relatively tight, uniform crumb. Some strive for that...I like a slightly larger less uniform crumb.
You need a bit more steam for better color. Ideally...more bread in the oven to provide the steam....if not that, then ice cubes on lava rocks as the loaves go in. Don't need a lot. For a small oven...maybe five ice cubes on four or five lava rocks (or chucks of firebrick left over from your build) piled up in a pie tin.
But the bottom line is that the bread looks great. Nothing wrong with that. No mouse holes. Decent color. Bravo.
Bill
