Proofing - raising questions????
  • Frances
    Re: Proofing - raising questions????
    Quick update: This time I went for longer rising times. Not quite as long as you suggest, the first trippling was more a sort of doubling, so it bubbled up faster and had to sit in the fridge till I was ready... I also added some malt, as the first loaf made me think that would be a good addition tastewise.
    But the bread really is better than with bought yeast! It has more texture somehow. Everybody loved it! As a newcomer to all this, I find it fascinating that all you need is flour and water to replace the yeast. Weird... cool!
    It didn't have a sour taste at all, which is great, because thats what my family objects to... propbably only beginners luck though. So my next question is: How do I keep the sour taste low?
    Here's a pic of one of the four small loaves, and one of the copious notes I had to make to get there...
  • John Fahle
    Frances:
    Congratulations on your first natural leaven bread! Even with the hurry-up method you described, I'm certain it has more flavor and texture than any straight-dough method bread, just because of the increased rising and proofing times. When you add that extra ferment, I think you'll be very pleased with the results. And the starter will just keep getting better with time, giving you a higher rise and more flavor. The first of a long line of great breads.
  • Frances
    Sarah, the mold was just a very small patch on the edge of the glass, so this time I'll risk it. If I thought it was developing throughout the starter of course I'd start over.
    John: somehow I thought it wouldn't be that easy... .
    I made a small loaf of bread yesterday, and to my complete and utter surprise it did in fact rise and produced an edible product that two out of five family members are prepared to eat for breakfast. So still plenty of room for improvement - I'll plan a proper three stage bread for next weekend.
    Thank you for all the advice!
  • John Fahle
    Frances:
    Easy answer: Scrape off the mold and keep going.
    Much tougher answer: The seondary sponge is really about flavor. You could make your dough directly from the primary sponge in a pinch, but it wouldn't be ripe, and wouldn't have near the flavor you want. It is the production of acid that gives natural leavens (or any breads) their flavor. THat's why straight dough method breads made with commercial yeasts have so little flavor. So the answer is yes, you can, but you really don't want to. THe reason you triple it twice is to give the yeasts that have already developed more fresh food, so they can continue to ferment for longer without overdeveloping and thus starving to death.
    Now, let's make sure we have the math right. You want to keep at least half your starter. You say tripling that would give you too much sponge. So use less starter. (As Jim says, grit your teeth and throw some away, if neccessary. You'll get used to it). If you want to make two one-kilo loaves, you could start with, say, 100 grams of starter. Triple to 300. Throw away 100 grams starter, and refresh your starter with 100 g water, 100 g flour, let ripen a bit, and put back in the fridge. After your primary sponge is ready, "triple" your primary sponge to 800g (40% of two kilos, if it's still winter where you are). Let ripen, then make the dough, autolyze, knead, rise, divide, rest, shape, bench-proof, slash, bake. Patience. You're gonna love this stuff.
  • sarah h
    Thanks Jim. Since I haven't begun yet, I'll go with white flour. And maybe look for that Reinhart book too.
    So if my starter is all bubbly and developing mold, that means its ready to use or refrigerate or feed ...
    Frances, if it's growing mold, wouldn't this mean it's time to start over?! They're not all penicillin ...
  • Frances
    Thank you Jim!
    So if my starter is all bubbly and developing mold, that means its ready to use or refrigerate or feed, even though I only started it last Tuesday?
    Ok, I'll feed it then, and use the other bit for a small loaf of bread, just to see what happens...
    I used spelt because its the most natural wholemeal flour I had in the house at the time, but I'll start feeding it regular flour from now on.
    Thanks again, I'll let you know how it turns out...
    "May your starter live long and prosper" - I love it!
  • CanuckJim
    Frances, Sarah, John,
    I certainly have The Bread Builders and certainly admire David Wing. However, the clearest, simplest, most foolproof method I've ever seen of developing and nurturing a starter is contained in Peter Reinhart's The Bread Baker's Apprentice. It's not perfect, but almost, and certainly dispels the mystery and voodoo out there. Another clear, fine approach is from David Hamelman in Bread. The development of mold is a sure sign that the starter is getting too warm. Once it's reached full maturity after a feeding, either use it or refrigerate it. There are lots of bugs, good ones, in a mature levain, but you don't want to create an environment that welcomes the bad guys. When developing a starter, it's important to keep it feeding actively but not let it get too warm. True, if you keep doubling it, soon enough you'll need a forklift to move it around. Grit your teeth and toss half of it.
    At least in the early, developmental stages spelt will not have the strength to develop a strong starter. Once the culture is well established, though, you could take a portion and try making a spelt starter, but I'd use it only in small proportions at first, then see how it goes. Really, the best flour to use when creating a starter from scratch is hard, unbleached bread flour. Again, once established, you can turn it into a whole wheat or rye starter as you will. Hamelman is very good on this subject.
    Jim
  • sarah h
    Very informative & interesting, and something I can do while I wait for spring to unbury my oven - thanks John!
    I tried to make starter a year or so ago and things 'started' out great, but sometime into the process, I began to question the look and smell of the stuff and when I tried to make bread it just didn't work. Thanks to the FB forum, I'll try again and post a distress call here if need be.
    I've copied all the information into a document I can shorten and print out to work with a bit more easily and, like Frances, may try spelt, since I have a bag of it in the cupboard.
    Now, if only it works for me - actually, for all of us trying to harness those wild yeasts ... may our starter 'live long and prosper'!
  • Frances
    ... having done some more advanced math, wouldn't it also be possible to make bread out of 500 g of flour and use just half the starter, without an additional startup period? Say if I was being spontaneous and wanted to bake the same day?
    Another question: as I said my starter seems to be glooping along nicely, but today I noticed a small spot of mold on it... so do I remove it and continue? Or have hysterics and toss the lot?
    The book is on its way, but for the time being I'm afraid I'm like a little lost lamb in need of guidance.
  • Frances
    Ok John,
    I've got my starter with 200g of flour and 200g of water, seems to be coming along nicely after nearly a week. I used Spelt (an older form of wheat, so wikipedia tells me).
    So here's my question: How important is all the math in this?
    If I want to use 1 kg of flour and I tripple the starter once, I'll have way too much starter already. So say I'm lazy and go ahead and tripple the starter. When its ready (about 12 hours later, right?) I add 1 kg of flour and say 550 g of water, which without starter would give a rather dry dough, but with should even out. Then I guestimate the salt for a bit more than a kg.
    Would that work, or will something go horribly wrong? And does the starter have to be trippled twice, or is that just to it get up to a larger amount?
  • gjbingham
    Thanks for the nice comments John and thanks for the explaination. To a point, the yeast explaination makes sense. Interesting topic. There's probably tons of scientific studies available on the subject, but I find that the baker's POV is often the most valuable.
  • John Fahle
    Frances: It makes much more sense when you try it. And if you don't have it yet, get a copy of The Bread Builders that GJ mentioned. It is the Holy Bible. It doesn't contain recipe one (or even formulae), but it contains more information about a holistic understanding of bread than any other source. Daniel Wing, with his bizarre renaissance man background as M.D./gypsy caravan builder is in a unique position to truly understand both the art and the science of bread. And he conveys it very well. You think your head hurts now? Just wait.
    GJ, thank you again. And I don't pretend to have Daniel Wing's understanding of the science of dough (which is why I try to skip it all when I post). But you are correct that you have quite a bit of leeway, and I think this is why: it's all about time, not volume. Given time enough, and food, any amount of yeast will replicate into "enough" yeast. And given time, any amount of yeast will replicate into "too much" yeast (overproofing). Remember, you don't have any idea how many yeasts per oz your starter contains, anyway.
    In my last post, we "tripled" 18 oz of primary sponge into 96 oz of secondary. But we only did that because we wanted to end up with 96 oz secondary sponge, since we'd already decided to make 320 oz of bread. But if we wanted half as much bread, we'd have "tripled" 18 oz into 48 oz. If we'd wanted 120 oz of bread, we'd have "tripled" to 36 oz. The only thing that is affected is the time of the secondary ferment. But it's not affeted by much, since you're doing it in stages. In other words, if you put six ounces of starter directly into 320 oz of finished bread dough, it would take forever to make it rise, as compared to putting six ounces starter directly into 32 oz bread dough. But that's part of the reason for the variations in the time of the secondary ferment. You don't let it ferment for a set period of time; you let it ferment until it's ready. There is an illustration in The Bread Builders (I don't have my copy with me, or I'd give you chapter and verse) where he explains the french three-leaven method. And in the example he gives, they use something like an ounce of starter to make 100 pounds of bread, or something ridiculous like that. Again, because they add still a third leaven sponge, the time differences between starting the same amount of bread with a pound of starter or an ounce aren't that great.
    Compare to commercial yeast. In any commercial yeast, there are a known number of yeasts per volume. And they are both voracious and prolific. And their trainers inject them with performance-enhancing sugars in the recipes, despite recent congressional investigations. They'll do anything to win. It's all about speed. And they give you set rising times. So if you add a tad too many yeasts, the results will quickly get out of hand. Certainly if you double or triple the amount of yeast called for in a recipe (as we can easily double or triple or halve the amount of starter we begin with) your end product is likely to be less than satisfactory. And because everything is happening so fast, you can't correct for it by using time, the way you do with wild yeast. If you tripled the amount of commercial yeast called for in a recipe, you might have a one-minute window between proofed and over-proofed. Not to mention that the tiny little amount of ferment time that the bread gets to develop flavor would be even more restricted.
    So the short answer is, I don't think it matters one whit how much starter you begin with. I take out a random amount, weigh it, and start my calculations from there, based on how much end product I want. The only reason I can see for using a set amount of starter is if you always make a pre-determined sized batch of bread, and you don't want to go through the hassle of doing the math every time. Although there are several free online spreadsheets that will do the math for you.
    Canuck, if you're reading this thread, has this been your experience, or do you use some set percentage of starter?
    Having written all that, it just occurred to me that I misunderstood your post. You were saying you have a lot of latitude with ADY, not with wild. Well, I guess "a lot" is relative. As I said, if you tripled the amount of ADY, I don't think you'd be very happy with the results. On the other hand, you have more leeway with ADY than with instant, because of the relative percentages of live yeast cells. I forget the numbers, but active dry contains something like one live yeast per 100,000 dead cells, and instant contains something on the order of 1/10,000. The reason you have to activate the "active" dry is to let all those dead cells unwind from the little protective cocoons they form around the live cells. So if you put in a tad more instant yeast than the recipe calls for, you're going to exponentially increase the number of yeasts that will exist in the dough 20 minutes from now, and an hour from now. So if anything, you'd want to err on the side of not enough yeast, and just give it a little more proofing time.
  • Frances
    Yes, thank you for that explanation.
    My head hurts, too.
    I'll print it all out (convert it to metric ) and prop it up in front of me next to the wild yeast starter I started yesterday (if and when its starts bubbling). Probably one of those things that only makes sense whe you actually try it... I hope...
  • gjbingham
    Ouch, I've got a headache! As I said before, truely an impressive knowlege of baking bread John. I'll come back to this one over and over. Kind of a Wikepedia entry.
    So after that incredible dissertation, to which I can only sit and wonder, did I miss school that day (?), I'm still at a loss how much it matters if you use a little too much AD yeast in bread. I can understand that too little is not good, and too much will give you a yeasty taste, but it seems that there's a lot of lattitude with ADY. Am I wrong? I'm a little off topic with the trend towards wild yeast propagation, but its an interesting thread and somewhat related.
    BTW, awesome post John. I'm seriously going to re-read it a few times. I was just reading The Bread Builders book recently regarding a similar topic. I think it needs to soak in for awhile.
    Thanks for any help you (all) can provide.
    G.
  • John Fahle
    Originally posted by Frances
    Good post John! I love reading your stuff.
    So how much flour did you start off with? (I'll try to work out the amount of water on my own...) And what is your bread receipe - how much yeasty sludge for how much flour, aprox raising times etc?
    For the starter, Flour= 6 oz or so. Water= . . . well, you get it. For the bread, the yeasty sludge/flour ratio varies by seasons, but basically you want 40% winter, 20% summer. Sort of. FIrst you take out however much starter you feel like using. Let's say you're making 100 pounds of bread, and you feel like using 6 oz of starter (which is handy, since that's half our starter, and now we just refresh). It really doesn't matter. Triple your starter by adding equal parts starter, water (filtered, remember), and flour, by weight. Now wait twelve hours. If it looks ready -- and you'll learn what "ready" means, but essentially it means sticky and bubbly and, well, goopy -- then you triple it again.
    Except this time, tripling means something else. First, figure out how much dough you want. In the winter, divide by 2.5 (40%), in the summer, divide by 5 (20%). That's how much finished leaven sponge you need. So say you started with six ounces of starter, tripled it to 18 ounces, and now you want to make 20 lbs (320 ounces) of dough. (BTW, you can save yourself a lot of heartache by buying a metric scale, but then you have to go back to your drug-dealing conversion days to figure out exactly how much 9,120 grams of bread is). You know that (since it's spring here in Texas) about 30% of the final product will be leaven sponge = 96 ounces. So you need to turn 18 ounces of primary sponge into 96 ounces of secondary sponge. Therefore, you "triple" 18 by adding 39 ounces of flour ((96-18)/2) and 39 ounces of filtered water ((96-18)/2). Don't worry about the fact that it's not really tripled. The yeasties are weak on math, but strong on appetite.
    Anywhere from 4 to 8 hours later (depending on the temperature, the pH of the water, whether Venus is rising, whether God is mad at you, and a lot of other hyper-technical factors) your secondary sponge will start to look like your primary sponge did -- in a word, goopy. (BTW, if you want either more flavor or more time, the secondary sponge rising is a good time to retard the dough in your fridge. It slows down the second rise, and enhances the flavor a lot. The pics that I posted of the first bread from the clay oven we built were retarded for a week during the secondary sponge, because I got over-anxious and thought we were going to start baking a week earlier than we actually did. Tastiest mistake I ever made.)
    Okay, now for the hard part. Get out your calculator. We already decided we want 320 ounces of bread. We already decided we want 30% leaven sponge, because it's Spring here in Texas. Now let's figure out our hydration. Say we want a nice 60% hydrated, medium texture bread. And say we want it to be 10% rye, for a little added flavor. Forget the salt, forget the leaven sponge, and forget the 10% rye. All we want to know is how much total flour/water ratio we need. So we take 320, divide by 160 (100% flour plus 60% water, if you don't know why I'm using those numbers, google "baker's percentages") and then multiply by 60 to get the amount of water = 120 ounces water (Don't add it yet). Then we take 320/160*100 = 200 ounces flour. (Don't add it yet.) We want 10% of the flour to be rye, so now we need 180 ounces of white unbleached, and 20 ounces of rye. But what about the flour and water that were already contributed by the leaven sponge? Let's correct for those.
    We have 96 ounces of secondary sponge, of which we know (since we used 100% hydration in both of our sponges and our starter) that 48 ounces is filtered water, and 48 ounces is unbleached white. 120 oz. water - 48 oz. water = 72 oz. water that still needs to go in. 180 oz. unbleached white (notice we did our rye calculation first so that the rye is 10% of the total flour) minus 48 oz. leaven sponge unbleached white = 132 oz. unbleached white that still needs to go in. Now let's check our math.
    96 oz leaven sponge + 72 oz water + 132 oz unbleached white + 20 oz rye = 320 oz of dough. Check. Now we need some salt. Around 2% is usually good, a little less for an airy rise, a tad more for a denser, tighter crumb (sammidge bread). Remember, we want 2% of the flour, not 2% of the total (baker's percentages). So we need 200 oz flour * .02 = 4 oz salt.
    Stir. Autolyse. Knead. Rise. Divide. Shape. Proof. Bake to 200F internal temp.
    Technical? Yes and no. There are no recipes for great breads. There are only formulas, given in baker's percentages. It takes a few times doing it to start thinking that way, but once you do, you'll never need a recipe again. You'll be looking at recipes and automatically doing the math in your head to convert them to baker's percentages. And then you'll start playing with the hydration, playing with the salt content, various flours, retardation times, etc., until you realize that all that stuff about baking being a science, with exact measurements and regimented recipes and exact rise times, is just horsehockey. Baking is as much an art as any other form of cooking.
    Have fun, Frances, and welcome to the world of real bread.
