Re: Playing with sourdough
I do expect that starter taken directly from the fridge rather than from a recently fed starter will behave differently - it will take longer for the initial bulk fermentation. But what's the difference between spending a few days bringing your starter up to speed vs giving eight hours for the bulk fermentation (instead of 3-6 hours)? Once the yeast starts feeding on the starches in the dough, it's active. Now, if you are a commercial baker, you need more consistency than I can achieve with my lazy starter feeding schedule. I suspect the obsessive feeding approach is geared towards achieving consistent results in a professional kitchen, but I also suspect it's not a prerequisite to achieve good (but probably more variable) results.
I'm interested to know how much the different variables that affect the quality of the bread (ingredients, starter, mixing times and temps, rising and retardation, handling of the dough, and oven conditions) actually contribute to the end result. In my efforts to make good bread at home, where should I spend more or less energy?
(good stinky) So I took half out at 2:30pm. I added more flour, a bit of oil, salt, and a small amount of sugar. I mixed it in my mixer and added flour till it was just a bit sticky. Then I hand kneaded it for about 15 minutes. I used the window pane test and it looked good. So I let it sit for 3 hours till it doubled. Then I separated it into three pieces and put each piece in a loaf pan for a final raise..........That's where I am at now.. 6:15 p.m. I will cook it in a few hours hopefully.
