Here's an e-mail exchange with James Bairey on the issue of burning the bottoms of bread I've baked:
> James,
> I left a phone message this morning and this is a follow-up about burning the bottoms of loaves I'm baked in my Casa100. I've sent Tammy some pictures of the finished oven. It's a real delight to use. The burned bottoms have occurred twice before.
> I've looked around the "Forum" but haven't really seen any thoughts on this issue. Any ideas you might have would be appreciated.
> Here's the details of how I bake:
> I'm using the 65% hydration bread technique by Maver that was in the Forum. The thermometers are your BonJour for external temps and an instant read one for internal temps. I'm using oak and madrone to fire my Casa 100 until the dome is white for about an hour- the temperatures with just coals present after 2 hours are 900*F on the dome and 800*F on the sides; the coals were removed. At 3 hours since the fire was started and 1 hour after the coals were removed - door kept closed to even out the heat, the dome temperature was 640*F and the floor was 600*F. I cleaned the floor with a damp cloth and misted water into the chamber several times. Two leaves ( about 375 grams each ) went into the center-back of the oven about 10 minutes later; the center floor temperature at that time was 555*F. Got great oven spring when I checked it again in 5 minutes- misted once again. At 30 minutes in the oven, the loaves had a dark brown crust and internal temperature of 175*F - the bottoms looked a bit burnt even then. I removed the loaves at 40 minutes with an internal temperature of 199*F; the crust was a very dark brown and the bottoms had 1/8" of burnt crust. Floor temp of the oven was 510*F.
> I'll keep on experimenting - but any input you can give would really help me bake a better loaf.
> Thank you very much,
> MoonshineBaker
And his reply:
Hi
I got your voicemail also. I would definitely recommend posting this in the forum -- there are a lot of bakers in the group and I am sure you will get a lot of good tips. Your oven looks great!
Here are a couple of things that come to mind for me.
If you are baking a high hydration dough (65%) in a pretty hot oven (550ºF+), you might want to dry either a ciabatta or baguette. Those are thinner, and lighter shapes that cook faster. Jim W. pops out high hydration French Baguettes at his bakery in about 8 minutes. If you leave your loaves in the oven at that temperature too long to finish cooking the crumb to 205ºF, you will definitely burn the bottom.
If you want to stick to the large loaf and a boule shape, you should let the oven temperature fall further, and consider a lower hydration dough.
Those come to mind for me.
Glad to hear you are enjoying your oven -- and definitely add this to the forum. We can all learn from this.
Regards,
> James,
> MoonshineBaker
And his reply:
Hi
Regards,
