using fresh ground flour?
  • Xabia Jim
    • Dec 2006
    • 1168
    Is anyone grinding their own flour?
    I had good intentions and bought an electric mill
    ...but have just been too lazy to use it.
    I know of local bread store in Michigan that grinds their own flour and they do have some awesome breads.....
  • Dutchoven
    • Apr 2007
    • 931
    Re: using fresh ground flour?
    Fresh flour definitely makes great bread...sadly we don't grind our own...here I think they would REALLY look at me like I was from Mars if I asked about the real whole grain at a store...
    Dutch
    • CanuckJim
      • Jan 2006
      • 1480
      XJ, Dutch,
      I've looked into the idea in detail but never have actually done it. A good burr grinder (that does not overheat the flour) will run in the area of $400, and they say you can grind the 20 lbs. of flour in an hour. However, you can't just use it as you grind it, I'm told, but have to let it oxidize naturally for about three weeks. This could lead to storage and temperature issues, not sure.
      Jim
      • gjbingham
        • Sep 2007
        • 2021
        My grain mill for grinding malted barley for brewing makes pretty fine flour, even unintentionally. Sounds like it would be fun to try. CJ, what does the oxidation accomplish?
        GJBingham
        • CanuckJim
          • Jan 2006
          • 1480
          George,
          I've worked with freshly ground, so-called "green" flour." Let's put it this way: it does not knead, doesn't form, isn't workable, doesn't rise properly. I'm not enough of a chemist to give you a better explanation. Let's just say it does not work without a period of being exposed to air.
          Jim
          • gjbingham
            • Sep 2007
            • 2021
            Thanks CJ.
            Interesting, not enough air time - no good. Too much air time - no good! Funny that in all the books I've got about baking, pasta, cooking, etc., none really explain the wonder of flour adequately. I guess I'll have to research it myself..... Hmmmm, maybe next year! I think the bathroom needs cleaning first.
            GJBingham
            • gjbingham
              • Sep 2007
              • 2021
              OK, the bathroom's clean. Research......Flour oxidation and formation of disulfide bonds. Magic! Grind it, store it, good to go for two weeks? Tons of information, mostly by commercial enterprise trying to sell something. Apparently, its a well defined process that has been so refined over the years that no one really discusses the processes anymore.
              I've got no problem accepting the flour industries treatment and prep of our building blocks. The bleaching of flour sounds absolutely terrible when you read about it.
              GJBingham
              • Xabia Jim
                • Dec 2006
                • 1168
                I'll have to ask at the bread store next time (Next month) how long they wait from grind to bread....never knew that one CJ....thanks!
                • CanuckJim
                  • Jan 2006
                  • 1480
                  George,
                  Using bleached flour is a no-no, at least all the bread books I value give good reasons for not using it. (Short answer: why would you?) Why they started bleaching flour in the first place escapes me. Using bromates is partiularly nasty, and it's been banned in the EU. The so called enrichment of flour with vitamins, iron, folic acid, etc. is mandated by law in North America, but it's really a left-over from the Great Depression when it was begun to help out with malnourishment ailments like rickets. Organic millers are pretty quiet about it, but many do not enrich their flours in this way.
                  It's worth pointing out that most North American mass produced bread is made using bromated (I call it "stepped on") flour, tons of Instant Rise yeast, whipping techniques you don't want to know about, and additives you can't pronounce. A loaf of this bambi bread can be squished into a ball smaller than an orange for good reason: it's mostly air. Side my side, a loaf of this bread might weigh, say, 8 ounces, despite its size, while a similar sized loaf of my bread will weigh a pound and a half. Go figure.
                  XJ, most, but not all of the flours I use have a mill date stamped on the bag so I know where I am with timing. I have no idea why supermarket flours don't have this, as well as a best before date.
                  Generally speaking, flours with higher bran and germ content (real whole wheat, whole rye) do not last as long as more finely milled and sieved flours, principally because of the oils present. It's the oils that go rancid without proper storage or freezing, and that's what gives the tell-tale "off" smell when the flour's gone bad.
                  George, look into Reinhart's Bread Baker's Apprentice or Hamelmann's Bread; both have in depth discussions of flour types and the chemistry involved from a baking perspective.
                  Jim
                  • gjbingham
                    • Sep 2007
                    • 2021
                    Thanks CJ. I've read the Reinhart section of flours recently. I didn't find what I was looking for, though I don't even remember now why I was searching.
                    I read last night that they started bleaching flour to do away with the storage time required for oxidation - it cuts down on costs.
                    I love your term "Bambi Bread". The kids love that bread, but of course cut off the crusts. Seems like a waste of time to try to get them to appreciate great bread at ages 6 and 7. They don't even like the dark spots on the pizza crust. Waaaaaaa
                    GJBingham
                    • Frances
                      • Aug 2007
                      • 2186
                      My kids may drive me up the wall sometimes, but their new favourite bread is my homemade stuff and their new favourite food is homemade pizza. They can get away with quite a lot when they say nice things like that. ...Yours are bound to come round to it sooner or later George.
                      Jim, what you need to do is buy one of those old wind mills you've been going on about, fix it up, and then you can start milling your own flour in a big way. You could start milling flour for the rest of the forum while your about it.
                      • Xabia Jim
                        • Dec 2006
                        • 1168
                        Hey Francis, just found out today that they're restoring one of the windmills to actually grind flour ...might be the one in the picture.
                        ...stay tuned, that could be some fun!
                        Happy Xabia
                        • gjbingham
                          • Sep 2007
                          • 2021
                          ...or build your own mill, miniature style. Just enough to supply your needs, and some for your friends who donate their own products.
                          GJBingham
                          • Xabia Jim
                            • Dec 2006
                            • 1168
                            if the wheat prices keep going up I could see that happening.....but I'd opt for a water wheel I think....
                            • MoonshineBaker
                              • Oct 2007
                              • 31
                              I have an old Marathon UniMill ( 1/2 HP motor, burr and stone elements with variable spacing between the grinding surfaces to give results from a fine flour to cracked grains) with which I grind hard red winter wheat berries. I'll sometimes throw in 10-15% rye berries. The temperature of the flour coming out is about 100*F. For the last 2-3 years, I have made what family and friends say is excellent whole grain bread.It's been even better since baking it in the outdoor wood fired oven! I follow the recipe, more or less, in the Tassajara Bread book (no dairy products used). The fresh ground whole wheat makes up about 50-60% of the flour; Giusto's Baker's Choice ($21.00 per 25 pounds) makes up most of the rest with maybe 2-4% high gluten flour (70% protein). I add some lemon juice and sometimes raisins and walnuts for a breakfast bread. It kneads well; develops gluten and passes the "window test" per Reinhard. The crumb is denser than the other breads I make but there are plenty of spaces/holes in a piece. The texture is nice and the flavor scrumptious. Hope this helps. Richard
