Re: Big sourdough spring
Chuckster,
There a many, many types of docking blades/knives. Some are serrated and stiff, with sharp points or round points. These are used mostly for stiffer doughs, like rye. The curved blade, called a lame in French, is used for the French grigne cut and many others. Bread competitions in France take the accuracy, effectiveness and decorative nature of the cuts into account when judging. It is they who come up with a lot of these names. The Wood-Fired Bread Cookbook has a pic of several types of blades.
Don't buy the plastic, fixed-blade lame. It's a bugger to sharpen, expensive, and you can only use one side of the blade unless you're ambidextrous. The retail operation of The San Francisco Baking Institute sells a Baker's Blade Holder for $6 USD: Baking Supplies|Baking Baskets and Supplies|Basket|Wicker Baskets |Plastic Baskets|Linen Liners|Proofing Boards|Wood Peel, or you could make one yourself. The holder uses standard double edged razor blades, which they also sell in bulk.
Having said all that, effective docking takes lots and lots of practice. You won't get it in one go; sort of like making pizza.
Jim
Chuckster,
Jim
